(Searched) Greddy Profec E-01 power supply?
Old Apr 1, 2006 | 11:52 AM
19t EX coupe's Avatar
Default (Searched) Greddy Profec E-01 power supply?
I searched, and mostly found WTB/FS threads, or just picture threads that don't answer my question...
(I have a 2000 civic EX coupe)
Question is, where can I wire in the 12v power wire for my greddy profec E-01? Does the power supply have to be continous, or just on when the car is in the "ON" position? The unit is in the glovebox, and I have 4ft of wire, if that helps.
sorry for the dumb question, but I always ask questions about wiring, since I'm afraid of frying or damaging something
thanks in advance, John
Old Apr 1, 2006 | 12:50 PM
Default Re: (Searched) Greddy Profec E-01 power supply? (19t EX coupe)
Bump
Old Apr 1, 2006 | 02:23 PM
Will the phone charger thing above the shifter work for an ignition based power supply? I just read that greddy needs an ignition based 12v source, so the battery will not work...
There's a yellow wire w/green stripe, and a solid black wire. I'm assuming the black is ground, so will the yellow/green wire work for an ignition based 12v source?
Old Apr 1, 2006 | 02:27 PM
john666's Avatar
you dont have the manuel ? you could wire it to the fuse box
Old Apr 1, 2006 | 02:32 PM
Default Re: (Searched) Greddy Profec E-01 power supply? (john666)
I have the manual, but it just says wire the red wire into a 12v ignition power source
Old Apr 1, 2006 | 02:35 PM
john666's Avatar
using a female connector conect that wire to i think it was D... A-E are + outputs if its not d just test it. its one of those
Old Apr 1, 2006 | 04:23 PM
ok, problem solved, I splice into the cigarrette light/power supply thing above the shifter, and it works great
thanks for everyone's help
caliskier
Feb 2, 2008 10:44 AM
19t EX coupe
Apr 1, 2006 04:22 PM
b18tdelsol
Jun 7, 2002 12:47 PM
