Moon cut Valve cover
Old Apr 1, 2006 | 09:38 AM
Mr. Em1's Avatar
Default Moon cut Valve cover
I was wondering how you guys did the mooncut valve cover. I searched and didnt find what i wanted to see. I plan on using a hole saw but nobody was too sure about the size. So if you guys know the exact size please let me know. Its for a b series motor too.
Old Apr 1, 2006 | 09:17 PM
b18ccivics's Avatar
Default Re: Moon cut Valve cover (Ninefivejiggaja)
i done mine with a jig saw and a short blade, worked great
Old Apr 1, 2006 | 09:47 PM
Mr. Em1's Avatar
where did you get the measurements? I was just planning on usin g a holesaw, because then i wouldnt have to worry about having an unsteady hand
Old Apr 1, 2006 | 10:08 PM
SJcivic's Avatar
Default Re: (Ninefivejiggaja)
Just find the centerpoint of the cam pullies and use the appropriate holesaw, nothing to it. Just be sure you have time to do some cleanup work... and paint
Rich
Old Apr 1, 2006 | 10:57 PM
ExVtec's Avatar
I scored mine with a dremel on the outside, then took some pliers and it just snaps off..
Pretty simple actually..
Old Apr 2, 2006 | 04:00 AM
2point2's Avatar
Default Re: Moon cut Valve cover (ExVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">I scored mine with a dremel on the outside, then took some pliers and it just snaps off..
Pretty simple actually..</TD></TR></TABLE>
same here.. just gotta use high quality bits and take your sweet time.
Old Apr 2, 2006 | 06:53 AM
ccarver's Avatar
I used a large draw punch from the shop. Found one close to the same size and let it rip.
Carver
Old Apr 2, 2006 | 09:07 AM
Muckman's Avatar
Moderator in Chief
How do you get it perfectly centered?
Old Apr 2, 2006 | 09:53 PM
ScorpioMk's Avatar
Default Re: Moon cut Valve cover (Muckman)
maybe if u have a spare camgear laying around hold it up and use it as a template.
Marcus
Old Apr 3, 2006 | 05:47 AM
autosport7's Avatar
Default Re: Moon cut Valve cover (ScorpioMk)
i just use the plasma cutter
Old Apr 3, 2006 | 07:51 PM
Mr. Em1's Avatar
word ill just borrow osmebody else cam gear or something
Old Apr 4, 2006 | 07:57 PM
JDMCRX's Avatar
Default Re: (Mr. Em1)
Easy way.
Take a piece of cardboard cut it out the same size as the cam gears.
take the side cover off and put the valve cover on and place the templets in the same area and volla cut away. Cut bellow the line then small dremel and grind clean to the line.
Josh
Old Apr 5, 2006 | 02:46 PM
turbofunvtec's Avatar
Default Re: (JDMCRX)
i'll be using a mill
also to clean off the raised letters once i'm done powder coating it.
Old Apr 5, 2006 | 08:55 PM
1 2 NV's Avatar
Default Re: (turbofunvtec)
90 degree hole hog with a hole saw appropriately sized. the center of the cam bolts is right at the seam between the plastic and the valve cover. just line it up and drill.
Old May 3, 2006 | 05:22 AM
eddie_ek's Avatar
Default Re: Moon cut Valve cover (b18ccivics)
Great job on the valve cover but question you have coil pack on your car is that better ignition spark
Old May 4, 2006 | 06:07 AM
kranked91dx's Avatar
plasma, took the mesurement from the pulley itself with a tape, got the radius... drilled a metal screw where the center of the puller are, took a peice of rope and tied the plasma torch to the metal screw... then did a moon, that way both are smooth and identical!
hope this help
jp
Old May 5, 2006 | 07:58 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Moon cut Valve cover (eddie_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie_ek &raquo;</TD></TR><TR><TD CLASS="quote">Great job on the valve cover but question you have coil pack on your car is that better ignition spark </TD></TR></TABLE>
lol yeah, not just one pack though, one for every plug, whats up with that?
Seems a bit strange to me, is it a photochop, or something that actually works?
Old May 5, 2006 | 11:31 AM
snoochtodanooch's Avatar
Default Re: Moon cut Valve cover (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Seems a bit strange to me, is it a photochop, or something that actually works?</TD></TR></TABLE>
i'm sure it does. but another notable is the powersteering line in the picture... soo...
Old May 5, 2006 | 12:23 PM
unusual71's Avatar
alot of new cars run a single coilpack per cylinder, hell even my old man's GMC truck runs 'em like that
Old May 5, 2006 | 12:32 PM
tallyturbo's Avatar
Default Re: (unusual71)
i believe its called coil on plug. alot of all motor guys use it i think
Old May 5, 2006 | 01:33 PM
b18ccivics's Avatar
it works, one of the best things i have done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">
i'm sure it does. but another notable is the powersteering line in the picture... soo...</TD></TR></TABLE>
boosted b18c ac ps cruise, only took out washer tank, ex car full interor and a floor jack in the back 12.4 @110 on 8.5 pounds of boost.
Old May 5, 2006 | 06:23 PM
Hype-R Stalker
You pretty much take the dizzy out of the picture when you do that, right?
How exactly do you set something like that up, and do you have anymore pics?
Old May 5, 2006 | 11:22 PM
Elwuudz's Avatar
<U>I scored mine with a dremel on the outside, then took some pliers and it just snaps off..
Pretty simple actually..</U>
word
scspeed
Mar 6, 2008 04:02 AM
98GSRDC2
Apr 25, 2007 09:25 AM
Thanks knightsport!
May 5, 2006 06:31 PM
D for D series
Jan 9, 2005 08:07 AM
Nishant
Honda S2000
Nov 8, 2004 10:55 AM
