Skunk2 Stage 1 cams
Old Apr 3, 2002 | 11:27 PM
98CivicDX's Avatar
Default Skunk2 Stage 1 cams
How much HP shall I expect from just dropping these bad boys into a b18c1?
Old Apr 5, 2002 | 01:19 PM
98CivicDX's Avatar
Default Re: Skunk2 Stage 1 cams (98CivicDX)
UP
Old Apr 5, 2002 | 02:00 PM
StinkyTofu's Avatar
15 drop in, 20 tuned.
Old Apr 6, 2002 | 10:43 PM
98CivicDX's Avatar
Default Re: Skunk2 Stage 1 cams (StinkyTofu)
Wow 15 is great if that's just drop in... Thx stinky
Anyone wanna give some rough estimates of what I'll be running in the 1/4 with a stock GSR with just these cams and nothing else? Not even exhaust or intake.
Old Apr 6, 2002 | 10:54 PM
StinkyTofu's Avatar
Hm...i highly suggest you make your engine breathe better before you just drop these cams in...seriously. When i said a drop in 15 horse power, i thought you at least had the basics. I was just going off of what other people get with itr cams. Most say they get like a drop in of 10 horsepower with ITR cams. Since the stage 1's make about 6-7 more horespower i just estimated a drop in of 15 horsepower.
Old Apr 10, 2002 | 03:22 PM
NoSpeed's Avatar
New User
You freakin liar. You don't own a civic. You own a Prelude!!!!!
Old Apr 11, 2002 | 03:05 PM
hondarookie's Avatar
Default Re: Skunk2 Stage 1 cams (NoSpeed)
Stinky I am new to this I want to know what kind of cams I should use for My Civic HX?
Old Apr 11, 2002 | 04:03 PM
StinkyTofu's Avatar
Default Re: Skunk2 Stage 1 cams (hondarookie)
If you already have the basic bolt ons (i/h/e), the skunk2 stage 1 cams are excellent for that kinda fairly stock motor. Just drop it in, get some new valve springs, retainers, chipped ecu, a skunk2 intake manifold, cam gears, and DYNO TUNING and you will make good power . For a mild cam i recommend the skunk2 stage 1 just from what i've heard about it. Everyone seems to be satisfied with it. Either that or the Toda Spec A if you have the money.
Old Apr 11, 2002 | 04:10 PM
LOwrestling2001's Avatar
hey u have an HX? that's a SOHC...skunk2s only make DOHC vtec cams...u can get like regrinds or somethin i know some companies make single cams...check that out...
Old Apr 11, 2002 | 04:13 PM
poison's Avatar
if u have the stock motor VTEC-E, there's no performance cams (as far as i know) for a d16y5, vtec-e is pretty different from regular vtec.
Old Apr 11, 2002 | 04:25 PM
Malice's Avatar
New User
Default Re: Skunk2 Stage 1 cams (poison)
skunk is making cams for sohc motors, also i hear good things about the ZEX cams for the sohc motor. those are available now
[Modified by MaliceGSR, 1:25 AM 4/12/2002]
EduardoDC5
Aug 21, 2010 10:23 AM
pearlteg
Aug 7, 2007 06:46 AM
Eric R
Dec 24, 2003 09:07 AM
riceball777
Oct 19, 2003 09:53 PM
jdm-spec-eg
Nov 11, 2002 06:37 PM
