is my master cylinder going bad? *pics inside*
Old Apr 1, 2006 | 08:01 AM
jdmjeff's Avatar
Default is my master cylinder going bad? *pics inside*
here are some pics of the rear of the master cylinder. also i have a gsr shell w a good master cylinder! Are a b16 and b18 the same? THANKS!
Old Apr 1, 2006 | 08:22 AM
jdmjeff's Avatar
Default Re: is my master cylinder going bad? *pics inside* (jdmjeff)
anyone?
Old Apr 1, 2006 | 08:25 AM
90civichb's Avatar
looks to me like the seals are taking a crap all over the inside. I would definately look in to replacing it or getting a rebuild kit (if they make them for our cars, I don't know..)
But for the answer, yes, the master off the other car should fit as long as it lines up with the mounting holes, which as far as I know is the same for all years w/ hydro trannies (feel free to correct me if Im wrong on this)....
Good luck, its not too hard of a job, but it could be kinda messy w/ clutch fluid needing to be drained before you start...
Old Apr 1, 2006 | 08:45 AM
jdmjeff's Avatar
Default Re: is my master cylinder going bad? *pics inside* (90civichb)
kool anyone else?
Old Apr 1, 2006 | 08:48 AM
Nevaeh Speed's Avatar
That seal is shot for sure or someone is teasing you with wd-40.
Old Apr 1, 2006 | 08:50 AM
jdmjeff's Avatar
Default Re: (Nevaeh Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nevaeh Speed &raquo;</TD></TR><TR><TD CLASS="quote">That seal is shot for sure or someone is teasing you with wd-40.</TD></TR></TABLE>
haha yeah right... but do you know if my gsr master cylinder would work?
Old Apr 1, 2006 | 08:52 AM
BALLIN H22 EK's Avatar
Default Re: (jdmjeff)
yea the seal is blown the gsr should work i looked at mine on my 98 hatch and looked at my friend teg and they looked the exact same
Old Apr 1, 2006 | 08:53 AM
90civichb's Avatar
what year is the car your drive, and what year is the gsr?
As a matter of fact, all that matters is that they are one of these vehicles:
92-00 Civic
94-00 Integra (&lt;-might be 01.. I dont' remember the generation ending year)
93-97 Del Sol
If both cars fall in to any one of those categories, the clutch MCs are interchangeable.
Old Apr 1, 2006 | 09:00 AM
bsixteen's Avatar
how are you guys telling if the seal is messed up? i don't see anything leaking or signs of leakage.
Old Apr 1, 2006 | 09:13 AM
Default Re: (bsixteen)
there is fluid and **** all around the seal...
but how about the clutch pressure has it been getting weaker? or has ur clutch fluid been gettin low lately??
Old Apr 1, 2006 | 09:17 AM
jdmjeff's Avatar
Default Re: (BALLIN H22 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK &raquo;</TD></TR><TR><TD CLASS="quote">there is fluid and **** all around the seal...
but how about the clutch pressure has it been getting weaker? or has ur clutch fluid been gettin low lately??</TD></TR></TABLE>
it got really weak last night i barely made it home and the fluid stays low!
Old Apr 1, 2006 | 09:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">
it got really weak last night i barely made it home and the fluid stays low!</TD></TR></TABLE>
then i say thats ur problem most likely look on the firewall where it is and see if its leakin out there too... really should replace it
Old Apr 1, 2006 | 12:09 PM
dohcdelsol's Avatar
yours looks beat up and if ur losing pedal pressure, time for a new one.
but i greased up all that area, rod, bushing part, and spring to get rid of that damn squeek
Old Apr 1, 2006 | 12:51 PM
JunY's Avatar
Default Re: (dohcdelsol)
Is it just me or do you guys not see the huge cracks underneeth? Or is that plastic?
Old Apr 1, 2006 | 01:13 PM
90civichb's Avatar
Default Re: (JunY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunY &raquo;</TD></TR><TR><TD CLASS="quote">Is it just me or do you guys not see the huge cracks underneeth? Or is that plastic?</TD></TR></TABLE>
That is a plastic and foam piece that reduces noise and heat from the front of the car.
It is cracked and messed up from being in contact with brake fluid (clutch fluid).
Old Apr 1, 2006 | 06:08 PM
NRZero's Avatar
Default Re: (90civichb)
Replace that as soon as you can. Mine looked liked that and then a couple weeks later the pedal just dropped to the floor. Tried bleeding it for a least two days straight but it would regain pressure. So I got rid of that and got a new one from Honda. Its works perfect now with no problems.
Old Apr 2, 2006 | 12:38 PM
dohcdelsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichb &raquo;</TD></TR><TR><TD CLASS="quote">
Its the fire wall mat, and it serves a very important purpose other then reducing noice and heat. I have heard that it will help the driver/passenger, in case of a fire from the engine, and give them enough time to get out of the car before the fire would to reach them. This will deff not prevent the fire from reaching the cabon all together. But this is only hear say as i could care less what its really used for.
Old Apr 2, 2006 | 12:48 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">how are you guys telling if the seal is messed up? i don't see anything leaking or signs of leakage.</TD></TR></TABLE>
uhh...note the gunk and all that **** around it
801ef
Nov 15, 2008 07:25 AM
twiztid00002
Oct 7, 2008 11:23 AM
