FS: Parting out EK, EG driver bags, OBD0 B16 parts (Virginia)
I am parting out a 97 hx (gone or damaged: pass. door shell, hood, bumpers, fenders, dash and airbags). I still have the dash pieces minus the climate control bezel, also I have everything for the power window conversion. Also parting a wrecked si but most of the remaining pieces are wiring and misc. pieces. If you need something specifically, pm me and I will get back to you. These car parts I am basically taking offers. Any <U>reasonable</U> offer will pretty much take the item.
Also have 5 EG driver side airbags (One has a scrape). $35 shipped a piece for these, minus $5 for the one with the scrape.
Have an OBD0 B16 which is probably best for parts cuz it has a crack in the far right cylinder and that same piston/rod are damaged. On the head, the same cylinder dome is rough looking (I assume the engine was sprayed on in the past. (I bought the engine in the condition it is in right now with the exception of minor disassembly).
Thanks and hit with up with what you need!!!
Modified by Hittnthebz at 4:02 PM 3/16/2007
Hey would you but dont know if its possible. to get the rear quarter panel from the civic hatch 97 on the passenger side. ALso would you ahve the wiper switch, the tunsignal as well. If it has the switch for rear wipers. THanks patai
I am sure it can be done but not sure if it would be worth the trouble. If you want, I can try to get it off for you, but I am not doing all of that work for cheap price on the part(too much to drill).
Also, I sold one of the switches, not sure which one.....ill check on that for you!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H8ted Ek »</TD></TR><TR><TD CLASS="quote">Hey would you but dont know if its possible. to get the rear quarter panel from the civic hatch 97 on the passenger side. ALso would you ahve the wiper switch, the tunsignal as well. If it has the switch for rear wipers. THanks patai</TD></TR></TABLE>
Wiper switch is sold. I have the headlight/turn signal switch but the hx model doesnt have any rear wiper....lmk
do you have both power window door pannels intact, and full power window conversion with floor harness? if so how much picked up im in va beach...
also what color grey is it? the dark one or the light one im not sure if theres that many different greys but im sure that there is 2 of them.
if so what about all of the plastics in the car as well pretty much everything except the dash with all clips.... let me know.
NobodieNoes
Oct 25, 2009 04:53 PM
