Suspension & Brakes Theory, alignment, spring rates....
lower control arm
Old Mar 31, 2006 | 09:01 PM
94vtirozguy's Avatar
Default lower control arm
stripping the suspension to put in ES kit.
got everythign else off except the lower control arm end which is connected to the ball joint.
cotter pin and castle nut is off... anything i might need or am missing to get this off ?
according to manual it should pull straight off once the cotter and castle nut are off
Old Apr 1, 2006 | 06:15 PM
is the lower control arm tapered on the ball joint ? or should it be able to be tapped off ?
Old Apr 1, 2006 | 06:33 PM
PIC Performance's Avatar
Default Re: (94vtirozguy)
They have a special tool designed to remove the balljoint, but you run the risk of tearing the boot with it. There is a method that is more often recommended on HT that has cleaner results.
Either way, its somewhat difficult to get that lbj out, and in my experience its never just come right out, especially if its your first time pulling it.
Old Apr 1, 2006 | 09:14 PM
yeah i have taken apart the whole knuckle out and tried the lil ^&*&* still hasn't come out
Old Apr 2, 2006 | 09:16 AM
No way, get it back on the car its easier that way (at least, thats what the HT method calls for).
IIRC, and don't quote me on this...
Insert the handle of a ratchet wrench into space "A", and then push down on top of the hub with a lot of force (like step on it). That should seperate the LBJ from the LCA without much trouble.
Old Apr 2, 2006 | 06:22 PM
thanks for that....
i bought a ball joint seperator and tapped it in and due to dust guard did not get far..
will take off dust shield and see how i go, after that will make the sucker move.... upper ball joint was much easier
thanks for your help
Old Apr 3, 2006 | 08:09 AM
94eg!'s Avatar
#1 Super Guy
Loved
Trust me, the rachet method that PIC showed you is the BEST way to separate the lower ball-joint. Too bad that's the only ball-joint it works on...
Takes all of three seconds to do, and works every time...
Old Apr 3, 2006 | 03:13 PM
HamiltonRex's Avatar
Default Re: (94eg!)
I use a long piece of thick walled pipe.. stick it though and go under the jack point, then the other end sticks out from the front.. i push on it, and get someone to tap the side of the joint with a hammer..
balljoints suck
Old Apr 3, 2006 | 08:32 PM
Tornadom's Avatar
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">balljoints suck</TD></TR></TABLE>
Can you imagine your car without them?
unclematt
12
Jun 2, 2016 04:31 AM
butter99
27
Nov 28, 2008 04:53 PM
androide016
Jan 8, 2008 11:10 AM
94vtirozguy
Apr 14, 2006 11:37 PM
illusion
Sep 10, 2002 05:13 PM
