replacing dizzy, do you need to use timing gun?
Old Mar 31, 2006 | 05:29 PM
davidluko's Avatar
Default replacing dizzy, do you need to use timing gun?
My question is pretty simple and I'm 90% sure I know the answer, but I want to make sure (cause mistakes on the engine aren't cheap ). When replacing my dizzy, do I need to align it exactly like it was before or can I just pop it on, eyeball it to close how it was before, and then let the ECU compensate for it? And how exactly does the ECU compensate? Explain that too. TIA
Old Mar 31, 2006 | 08:41 PM
formby's Avatar
Default Re: replacing dizzy, do you need to use timing gun? (Hatch_R)
with a sharpie make a line acros the top mounting point....and just align it back....i have a line for NA and a line for when i spray....
Old Apr 1, 2006 | 01:58 AM
davidluko's Avatar
Default Re: replacing dizzy, do you need to use timing gun? (formby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by formby &raquo;</TD></TR><TR><TD CLASS="quote">with a sharpie make a line acros the top mounting point....and just align it back....i have a line for NA and a line for when i spray....</TD></TR></TABLE>
What if I'm putting a different dizzy in?
Old Apr 1, 2006 | 05:14 AM
Jmunk's Avatar
Than you need a timing gun to retime it.
Old Apr 1, 2006 | 01:31 PM
davidluko's Avatar
Default Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk &raquo;</TD></TR><TR><TD CLASS="quote">Than you need a timing gun to retime it. </TD></TR></TABLE>
Alright thanks for the info. But then what do people say about jumping the service connector or it will reset itself (like when they turn the dizzy toward the firewall to advance timing)? Kinda confused on all that
BPoppert
Aug 12, 2015 06:52 AM
Civic-Kids
Sep 23, 2007 12:44 PM
philkehn
Oct 23, 2006 08:20 AM
