Rack and Pinion, steering wheel has a bit of play.
Old Mar 31, 2006 | 05:13 PM
dem0nk1d's Avatar
Default Rack and Pinion, steering wheel has a bit of play.
How do you adjust the rack and pinion on a 92-95 Hb Dx? OR is it possible to take the slack out of the wheel.
Old Apr 1, 2006 | 07:43 AM
dem0nk1d's Avatar
Default Re: Rack and Pinion, steering wheel has a bit of play. (dem0nk1d)
**bump**
Old Apr 1, 2006 | 07:44 AM
sohcvtec1995's Avatar
did you check your tierods? if there is play in the wheel then that could be your problem..
Old Apr 1, 2006 | 09:25 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (sohcvtec1995)
check tie rods, then the lower u-joint, etc. If all that is good, there IS an adjuster bolt on the rack. Look under your car and you will see a huge locknut with a 14mm bolt inside of it. You need to be careful with how much you tighten it though, because too tight and you're steering wheel will stay turned and behard to move. I forgot the adjustment procedure in the service manual, just go a 1/4 turn at a time. Oh, and you need the special tool to loosen the locknut...go make friends with a Honda tech
MotorMouth93
Jan 17, 2015 03:58 PM
uptownspeedstar
Feb 25, 2011 04:21 PM
q.man06
Nov 25, 2009 12:06 AM
ketchup
12
Aug 26, 2008 12:30 PM
Toptul_Honda
15
Jan 28, 2003 08:41 PM
