after hours of search i am still stuck on which cams to use.. HELP!!!
and so my set up is a jdm gsr with the usual I,H,E and a skunk2 intake manifold. my next upgrade is camshafts. i found a set of skunk2 stage1 cams for $400 and bc3+for also $400 and m22 cams for $500. i want a cam that gives me power throughout the whole powerband. help!! suggestions plz
if you wanna run a bigger cam then you are gonna need higher compression. it will give you the maximum power for the cam
M22s are probally too big for a GSR(I believe those are closer to stage 2s if not 3s). I'd also check into the blox stage 1s and 2s.
id say take 2 layers off your stock Head gasket and run m22x's with a rocket valvetrain. id also look into headers and an exhaust first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 »</TD></TR><TR><TD CLASS="quote">id say take 2 layers off your stock Head gasket and run m22x's with a rocket valvetrain. id also look into headers and an exhaust first</TD></TR></TABLE> I dont think doing that to your headgasket is a good idea
