clunk on accel or when i stop(91 dx ls motor)
Old Mar 31, 2006 | 12:56 PM
97grnrs's Avatar
Default clunk on accel or when i stop(91 dx ls motor)
when i accellerate or shift or especially stop abruptly in my 91 dx hatch with LS swap i hear a pretty loud clunk.. almost like a motor mount is loose but its not.. so far i have replaced the tie rods and control arms and all mounts and suspension are as tight as can be.. the motor doesnt even move when i drive so it cant be that but something is def hittin or rubbing cause i hear the noise every day.. the steering rack is tight and every single thing i check is tight and i still hear this? what could it be?
Old Mar 31, 2006 | 01:47 PM
Niftythang's Avatar
Default Re: clunk on accel or when i stop(91 dx ls motor) (97grnrs)
Check or have a garage check your lower ball joints.
Old Mar 31, 2006 | 02:15 PM
mintef's Avatar
radius rod bushings or upper strut mount bushings for sure
Old Mar 31, 2006 | 03:16 PM
Ak_ef9's Avatar
Default Re: (mintef)
might be some play in the tranny. I had that problem and it ended up being a bad diff
Old Mar 31, 2006 | 04:58 PM
ijjz's Avatar
I had a similar problem before, but I could also reproduce this by driving over a bump or a dip. Check out the radius rod, thats what fixed my problem.
Old Mar 31, 2006 | 05:02 PM
blumpfish's Avatar
Default Re: clunk on accel or when i stop(91 dx ls motor) (ijjz)
I had the same problem in my DA , it was an automatic, im almost positive it was the tranny though, and one of the motor mount was bad
norcali707
Honda Civic (2001 - 2005)
May 1, 2013 05:47 PM
CRX_RR
19
Mar 25, 2011 03:11 PM
bodiez
27
Apr 24, 2009 05:16 AM
i_VTEC
Oct 3, 2007 05:07 PM
csulliva
Nov 12, 2002 06:05 PM
