GSR suspension on 96-00 civic?
how much can transfer over?
i know the fron and rear brakes/hub assembly
but will the LCA on the fron and rears fit?
and that thing where the rack and pinion sits on...can't remember the name
if all that fits could i just mount GSR front and rear sway bars on without a problem, considering if i had GSR front and rear LCA's
sry werid questions thx
might be picking up a gsr for parts thats y asking
front lca i dont know, rears will not. the eg/dc lcas are about an inch chorter than the ek
afaik all ek rear lcas have holes drilled for the swaybars already, so the gsr lcas are unneccesary even if the did fit. and yes, you can run gsr sways without a problem, you just need the appropriate mounting brackets
tnbigdawg
Feb 2, 2003 06:24 PM
Pressurized
Nov 28, 2001 03:09 PM
