Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
ridgeline secrets....
Old Mar 31, 2006 | 09:31 AM
Jose.'s Avatar
Default ridgeline secrets....
not really secrets....just cool
The middle seat in the back has a secret hiding headrest. Pull up on it and you have a headrest for the rear seat middle passenger
The very top of the armrest (the soft part) slides forward
Press and hold the unlock button a second time on the keyfob and all door windows will open.
Twist the key in the door lock a second time in the same direction and hold and the windows will open or close!
After turning off the ignition key, the windows will still run up or down for a few minutes or until you open the door.
there is a pen clip and business card holder built into the lid of the center console.
The AM/FM antenna is built into the roof part that extends beyond the back window
The "bumps" or "ridges" on the side view mirrors is to reduce wind noise.
The optional bed cargo net can be folded in half and mounted vertically against the back of the cabin to hold smaller items.
The spare wheel can be mounted on the inside of the bed - handly if you know in advance you're going to be loaded up and don't want to risk having to unload if you have a flat.
Hit one of the windows with your arm as it's going up, it'll reverse and go back down
wind shield wipers slow down when you come to a stop and speed up again when you accelerate
Modified by Jose. at 12:19 PM 3/31/2006
Old Mar 31, 2006 | 11:29 AM
Honda318dx's Avatar
Default Re: ridgeline secrets.... (Jose.)
Sweet. I didn't know half that stuff..
Old Apr 3, 2006 | 05:43 PM
Tornadom's Avatar
Neat little things to know.
Old Apr 4, 2006 | 10:45 AM
Ponyboy's Avatar
Painting Masterpieces
Nice!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose. &raquo;</TD></TR><TR><TD CLASS="quote">
wind shield wipers slow down when you come to a stop and speed up again when you accelerate</TD></TR></TABLE>
Would either use frequently or appreciate, the above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose. &raquo;</TD></TR><TR><TD CLASS="quote">Twist the key in the door lock a second time in the same direction and hold and the windows will open or close!
Ehhh, maybe not so much. But would be thankful that I at least could.
Good stuff!
Old Apr 4, 2006 | 11:26 AM
.God.'s Avatar
Default Re: ridgeline secrets.... (Ponyboy)
speed dependent wipers? love it
Old Apr 5, 2006 | 12:48 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ridgeline secrets.... (..Lloyd Braun..)
Modified by Jose. at 12:19 PM 3/31/2006</TD></TR></TABLE>
Ok that is pretty cool.
Old Apr 5, 2006 | 08:18 AM
Del Sizzle's Avatar
Cool.
I knew about everything except for the spare tire mounting inside the bed. I'm going to check that out at Lunchtime.
Old Apr 6, 2006 | 08:31 AM
rookie_tt's Avatar
Old Apr 10, 2006 | 04:35 PM
EDwEFprts's Avatar
damn Jose.... you love ridgelines!
Old Apr 12, 2006 | 04:04 PM
Hondatec38's Avatar
Default Re: ridgeline secrets.... (EDwEFprts)
Some people don't know the headlights are auto-off also. Leave them on (ignore the dinging or beeping) and lock the vehicle with the keyless. They will turn off in a few seconds. I leave them on all the time.
Old Apr 13, 2006 | 09:17 AM
TRE_'s Avatar
Default Re: ridgeline secrets.... (Hondatec38)
Also, on some models, lower portion of windshield is heated to prevent blades from freezing/sticking in frigid conditions.
Climate control/AC is dependant on GPS/Sun position.. will turn up cool air output if sun is shining more so on one side as opposed to the other.
Theres a bunch of others but its been so long since I took the test I forgot a lot of them
Cool thread
Old Apr 13, 2006 | 09:30 AM
Jose.'s Avatar
Default Re: ridgeline secrets.... (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">Also, on some models, lower portion of windshield is heated to prevent blades from freezing/sticking in frigid conditions.
i had not noticed that.....nice
Old Apr 13, 2006 | 11:30 AM
.God.'s Avatar
throw in a straight 6 turbo diesel with a real transmission and beef up the rear diff and you have a winner!
Old Apr 13, 2006 | 12:04 PM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..Lloyd Braun.. &raquo;</TD></TR><TR><TD CLASS="quote">throw in a straight 6 turbo diesel with a real transmission and beef up the rear diff and you have a winner!</TD></TR></TABLE>
oh please..... just go ahead and admit you want to buy one.
CE1318
Dec 15, 2016 08:17 AM
1yesfan
Apr 30, 2015 08:31 AM
slikz714
Audio / Security / Video
Sep 16, 2008 05:21 PM
4drcivicls
Aug 27, 2008 05:31 PM
