Has anyone had a problem with this?? just curious.......
Old Apr 3, 2002 | 08:29 PM
BluElude01's Avatar
Default Has anyone had a problem with this?? just curious.......
Has anyone with a COld Air Intake had a problem with water getting sucked up into their engine causing it to hydrolock? I am thinking about buying a aem possibly and just wondered about taht? and how common it is?
Thanks
Old Apr 3, 2002 | 08:33 PM
typeSwarrior's Avatar
Default Re: Has anyone had a problem with this?? just curious....... (BluElude01)
It's rare--and it only happens if your entire filter is submerged in water (probably 10 inches deep). Unless you're in the back fields or really don't know when to avoid flooding areas, you won't have a problem. Doesn't hurt to drive cautious in the rain though, just don't drive around at WOT, even though that still won't suck enough water to get inside the intake manifold (just prevents hydroplaning ).
[Modified by typeSwarrior, 11:45 PM 4/3/2002]
Old Apr 3, 2002 | 08:41 PM
akkording's Avatar
New User
Default Re: Has anyone had a problem with this?? just curious....... (typeSwarrior)
Get an AEM air bypass valve and you'll be fine.
Old Apr 3, 2002 | 09:22 PM
94PreludeSi's Avatar
Default Re: Has anyone had a problem with this?? just curious....... (akkording)
if you know the water is too deep you can just pull your intake off the TB... for a short period of time of course
Old Apr 4, 2002 | 07:49 AM
prelude1897's Avatar
I had that problem about 10 months ago....
Old Apr 4, 2002 | 08:44 AM
Drelude's Avatar
New User
Go to the Accord Forum, there is a thread where the guy drove into a foot of water, his car cant start now.
Old Apr 4, 2002 | 09:19 AM
Mugenlude's Avatar
Default Re: Has anyone had a problem with this?? just curious....... (Drelude)
Don't go driving thru large puddles and you'll be fine. I ran thru a good size puddle once, shut car off, went under the hood, removed intake -- no water that I could see or feel on the inside of intake. Filter wasn't wet either. We have a splash guard there to that stops the normal road splashs.
Oh yeah. I have a AEM. I would worry about it unless you drive thru floods.
rathead81
10
Dec 20, 2007 10:44 AM
Vcastro
22
Oct 1, 2006 07:11 AM
Easy G
Mar 10, 2006 03:57 PM
sexysami
Sep 10, 2003 09:30 PM
