B20 VTEC QUESTION
Old Mar 31, 2006 | 08:26 AM
darklyte's Avatar
Default B20 VTEC QUESTION
I have been lookin for some b20 vtec pistons, im not sure what to get i want to be abel to run on 91 octain gas with no problems.what pistons would you all recomend?my set up is
98 jdm b20b block( stock sleeves)
95 gsr head
skunk2 valves,springs and retainers.and blox stage 2 cams
type r oil pump
type r water pump
rc 310 injectors
Old Mar 31, 2006 | 08:30 AM
Dan Ruddock's Avatar
Default Re: B20 VTEC QUESTION (ajdmek9)
If it is a street motor I would the RS machine cast 84mm itr pistons. Dan
Old Mar 31, 2006 | 08:31 AM
darklyte's Avatar
do you now what web sit i can order those from?
Old Mar 31, 2006 | 08:37 AM
Default Re: (ajdmek9)
Pro street imports
https://honda-tech.com/zerothread?id=1527541
Old Mar 31, 2006 | 09:47 AM
princess24's Avatar
Default Re: B20 VTEC QUESTION (vtecjj)
hey I would be interested in thos pistons as well give me a price
Old Mar 31, 2006 | 12:19 PM
acydphryck's Avatar
Default Re: B20 VTEC QUESTION (princess24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by princess24 &raquo;</TD></TR><TR><TD CLASS="quote">hey I would be interested in thos pistons as well give me a price</TD></TR></TABLE>
check my sig for Prostreet's #...i couldn't be happier with my motor...thanks for the plug Dan
Old Apr 2, 2006 | 11:37 AM
darklyte's Avatar
i ended up gettin JE 10-5 PISTONS. would i have to get new rods to??
Old Apr 6, 2006 | 11:19 AM
acydphryck's Avatar
Default Re: (miner-dma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miner-dma &raquo;</TD></TR><TR><TD CLASS="quote">i ended up gettin JE 10-5 PISTONS. would i have to get new rods to??</TD></TR></TABLE>
wait...so you got 10.5:1 pistons for your B20VTEC setup then??
Old Apr 6, 2006 | 11:19 PM
darklyte's Avatar
Modified by miner-dma at 12:31 AM 4/7/2006
Old Apr 25, 2006 | 03:40 PM
SuperImport's Avatar
Default Re: (acydphryck)
The rod length has to match up with the pistons you purchased stock rods should be fine but I would go with some eagles theyre not too expensive.. i forget the exact rod length but learch and youll find it
92integraVTECgsr
19
Sep 27, 2011 10:42 AM
jdm92teg
Nov 11, 2004 09:12 AM
ALLMOTORJ
Apr 13, 2004 11:07 AM
b20turbojason
Nov 12, 2003 05:33 PM
Maximus
Apr 6, 2002 01:47 AM
