Which, cams gears for b16a?
Old Mar 31, 2006 | 08:12 AM
96hondab16a's Avatar
Default Which, cams gears for b16a?
Would Type r cams gears fit? if so, do i need cams, new belt, pump, pulley or can i just leave it with the cam gears and be ok?
Old Mar 31, 2006 | 08:42 AM
NoBottleJustThrottle's Avatar
Default Re: Which, cams gears for b16a? (96hondab16a)
Why not just play it safe and get motor specific cam gears? When you say Type R cam gears, are you talking about the stock ones from a Type R, or aftermarket ones that were made for a Type R? If you are talking about the stock ones, that would just be a big ol' fat waste of time and money.
In terms of what to replace, I am pretty sure that it is highly recommended that you replace the belt with your cam gears.
Old Mar 31, 2006 | 09:21 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hondab16a &raquo;</TD></TR><TR><TD CLASS="quote">Would Type r cams gears fit? if so, do i need cams, new belt, pump, pulley or can i just leave it with the cam gears and be ok?</TD></TR></TABLE>
yes they fit, but why would you just want the gears ? if you wanna switch over to the type r stuff i recommend changing the whole valvetrain
Vanadium
Mar 23, 2008 11:21 PM
st3alth
May 26, 2005 07:39 AM
Try2Live4God
Jan 17, 2004 11:15 AM
bocian
Feb 21, 2002 09:16 PM
