valve adjustment??
Old Apr 3, 2002 | 08:19 PM
SIK IN DA HED's Avatar
New User
Default valve adjustment??
anyone have a valve adjustment done that caused more problems? i know my integ is in need of a valve adjustment bad... i just wanna make sure that if its not done right... it wont lead to more problems.
Old Apr 3, 2002 | 09:35 PM
mickey513's Avatar
Default Re: valve adjustment?? (dlplayboy)
I suggest just taking it to a mechanic. Should cost around $60. Save you a lot of time and headaches if you aren't too mechanical incline.....
Old Apr 3, 2002 | 09:37 PM
six_speed's Avatar
Default Re: valve adjustment?? (mickey513)
here is a site that teaches u how to adjust the valves and others.
Learn away.....
knock ur self out
go nuts
Old Apr 3, 2002 | 10:07 PM
New User
Default Re: valve adjustment?? (Lilmumbler)
i got a few friends who "know" how to do it. just wanna make sure that if they dont do a good job, it wont make matter worse.
Old Apr 3, 2002 | 11:14 PM
vteg's Avatar
New User
Does snapping a few of the adjustments bolts due to overtightening on my civic, during my first valve job count as a problem
BTW, so I don't look like an idiot(that did not sound good on second reading). I tightened the bolts, and had to go redo the exhaust side, because I used the wrong feeler guage. When I went to loosen them, most of them broke off.
Old Apr 4, 2002 | 10:30 PM
New User
Default Re: valve adjustment?? (vteg)
ouch. exactly why i wouldnt risk it. heheh at least if a shop mechanic broke it... i wouldnt have to worry about it cuz they would cover the damage.
JFG Kevin
Mar 21, 2005 06:39 PM
vulgar_si
Nov 18, 2004 05:31 AM
SLOW4drINTEG
Jun 20, 2003 02:59 AM
bocian
Feb 12, 2002 08:40 PM
