Honda S2000 Honda S2000
How much power does the air con rob from an S2k engine?
Old Mar 31, 2006 | 02:33 AM
djnikko's Avatar
Default How much power does the air con rob from an S2k engine?
I live in the UK and have a very rare need for Air Con (with our shitty weather we just put the window down)! On this note is it worth me removing the AC belt? or AC unit?
I just want to know if any extra power can be freed up
Thanks
Old Mar 31, 2006 | 05:13 AM
Sideways's Avatar
Default Re: How much power does the air con rob from an S2k engine? (djnikko)
The air conditioning has a clutch that disengages in Vtec. Some of the racers have removed the heater/AC to save about 75 lbs. If you decide to, don't spend a fortune on the Mugen drive belt. Just order this belt for removing AC: 4060450 (6PK1145) 45"
Old Mar 31, 2006 | 08:22 AM
RobbieG35's Avatar
12 Years Strong
Default Re: How much power does the air con rob from an S2k engine? (Sideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways &raquo;</TD></TR><TR><TD CLASS="quote">The air conditioning has a clutch that disengages in Vtec. Some of the racers have removed the heater/AC to save about 75 lbs. If you decide to, don't spend a fortune on the Mugen drive belt. Just order this belt for removing AC: 4060450 (6PK1145) 45"</TD></TR></TABLE>
Good info. I bet the Mugen belt is $11324078347884
Old Mar 31, 2006 | 09:54 AM
Sideways's Avatar
Default Re: How much power does the air con rob from an S2k engine? (HybridHatch88)
The belt is about $20-25 locally and $160 from Mugen.
Mr. Projekt's Avatar
* B A N N E D *
I'm running A/C-less also. The whole system, condenser and all, is about 50 lbs. There's very little difference in the feel of the motor itself, but it gave me some room in the engine bay to work, and changed the corner weighing a bit. I paid $14 for a Bando belt. I have the part # if you need it.
Hello Mr Sideways.
Old Mar 31, 2006 | 12:23 PM
RobbieG35's Avatar
12 Years Strong
Default Re: How much power does the air con rob from an S2k engine? (ProjektSlideways)
That does leave alot of room. Hmm. do you have a picture of your engine bay ProjektSlideways ? I would love to see it with all of the A/C lines out of the way.
Old Mar 31, 2006 | 12:38 PM
AP12001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">That does leave alot of room. Hmm. do you have a picture of your engine bay ProjektSlideways ? I would love to see it with all of the A/C lines out of the way.</TD></TR></TABLE>
you already free up a lot of room just by taking out the stock intake. regardless of whether or not you got AC, it shouldnt matter much.. thats what the top down is for.
Old Mar 31, 2006 | 02:08 PM
RobbieG35's Avatar
12 Years Strong
Default Re: How much power does the air con rob from an S2k engine? (AP12001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AP12001 &raquo;</TD></TR><TR><TD CLASS="quote">
you already free up a lot of room just by taking out the stock intake. regardless of whether or not you got AC, it shouldnt matter much.. thats what the top down is for. </TD></TR></TABLE>
Yea. The only time I missed A/C in my Si is when it would rain. Foggy windows sucked badly.
Old Mar 31, 2006 | 03:12 PM
* B A N N E D *
Couldn't find any full ones except this. Phone cam, taken about 3 months ago when I did the work.
Old Apr 1, 2006 | 12:42 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">I live in the UK and have a very rare need for Air Con (with our shitty weather we just put the window down)! On this note is it worth me removing the AC belt? or AC unit?
Thanks</TD></TR></TABLE>
Don't pull out the AC system. If anything, run the shorter belt to bypass the AC compressor. You'll regret pulling the entire AC system when you're returning your car back to stock so you can enjoy daily driving it in hot weather instead of having it parked in your garage for over a year.
Old Apr 3, 2006 | 02:01 AM
djnikko's Avatar
Default Re: How much power does the air con rob from an S2k engine? (vapor)
Hot weather and England dont really go in the same sentance
Is it only Mugen that make the belt? If anyone can post up some options of where I can get the shorter belt that would be appreciated.
Also would the A/C unit mess up if its not used for a long period of time. Is there any maintenance needed to stop it messing up?
Cheers
Old Apr 3, 2006 | 08:23 PM
* B A N N E D *
Bando makes the belt for $14. Goodyear Gatorback also does.
Old Apr 3, 2006 | 09:00 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">Hot weather and England dont really go in the same sentance
Cheers
Keep in mind the AC comes in handy to unfog your windshield in rainy conditions instead of rolling down the windows. I'm sure England gets sunshine most of the time
The compressor will be fine if you run a shorter belt over time.
Old Apr 3, 2006 | 09:26 PM
* B A N N E D *
That is true. I just reach up and wipe, then heat.
TcUiRvBiOc
Apr 26, 2008 06:16 PM
EnjoyTheRideDC2
Nov 23, 2005 08:07 PM
markysparky
21
Oct 30, 2005 08:03 PM
wizards581
Oct 23, 2004 12:20 PM
TwistedSI
Feb 21, 2004 06:36 PM
