skunk2 stage 3s + 1/2 mm oversize valves
Old Mar 30, 2006 | 06:12 PM
not so JDM Dan's Avatar
Default skunk2 stage 3s + 1/2 mm oversize valves
hey guys, i was wondering if anybody could tell me for sure if my skunk2 stage 3s (not pro-series) cams would work with 1/2 mm oversized ss valves. an old friend of mine ran half over valves with crower 413s and it worked fine. im not sure how different they are on overlap but i have the specs between the two cams if it helps.
skunk stg 3s
IN. .504, 272
EX. .469, 280
crower 413s
IN. .468, 263
EX. .468, 255
thanks in advance, any help would be appreciated. this is all on my lsvtec setup (b16 head)
Old Mar 30, 2006 | 06:53 PM
Tbone's Avatar
Default Re: skunk2 stage 3s + 1/2 mm oversize valves (JDMDan)
I ran them +3 -2 with .5mm over intake and ex... but that in no way means you can.. the position of the valve on the seat when the vjob was cut will dictate weather it can be done.. I have even run the pro-3's with a 1mm over intke and stock ex valve
Old Mar 30, 2006 | 07:02 PM
Default Re: skunk2 stage 3s + 1/2 mm oversize valves (Tbone)
ok thanks for the reply, so i gotta find out from the machinest how it was done... sorry i dont know much about this subject, what am i exactly looking for, i mean what position of the valve would let me run the cams? is it a stock position or a different angle? thanks
Old Mar 30, 2006 | 07:05 PM
DonF's Avatar
I have used the older stage 3's with + sized valves. Just check your numbers.
Old Mar 30, 2006 | 07:10 PM
Default Re: skunk2 stage 3s + 1/2 mm oversize valves (DonF)
sorry to sound like such a dumbass but what numbers? for dialing in the cam gears or degreeing the cams?
Old Mar 30, 2006 | 07:44 PM
Boner_Ben's Avatar
Installed valve height is the number you need.
DusdmCgsr2
12
Jul 28, 2006 07:30 PM
veilsides2000
Jul 26, 2005 06:30 AM
THCk20eg
May 23, 2004 10:13 PM
BolivianFuego
Nov 29, 2003 05:22 PM
sleepycivix
Nov 15, 2002 07:01 PM
