looking for complete JUN 3 cam specs?
Old Mar 30, 2006 | 05:31 PM
1 2 NV's Avatar
Default looking for complete JUN 3 cam specs?
im looking for complete cam specs. someones got to have degreed these cams before and about the only thing ive seen posted was centerlines.
Old Mar 30, 2006 | 06:05 PM
Dan Ruddock's Avatar
Default Re: looking for complete JUN 3 cam specs? (1 2 NV)
http://www.junauto.co.jp/produ...ml?en
Old Mar 30, 2006 | 07:16 PM
1 2 NV's Avatar
Default Re: looking for complete JUN 3 cam specs? (Dan Ruddock)
that doesnt show valve opening and closing cycles. as in the title, COMPLETE cam specs.
Old Mar 30, 2006 | 07:33 PM
Give me the lobe centers i know how to give you the numbers with that data. Dan
Old Mar 30, 2006 | 08:34 PM
1 2 NV's Avatar
i was told 110 degrees both IN and EX but a very good head porter said that didnt sound right to him.
Old Mar 30, 2006 | 08:50 PM
Doesn't sound right to me either. Also it is possible for the centers to be different on the primaries than the vtec lobes. The stock centers I have seen were different on the ex. and in. Dan
Old Mar 30, 2006 | 08:51 PM
1 2 NV's Avatar
i wish i could help you out but i just dont know unfortunately. thats why i posted up on here.
Old Mar 31, 2006 | 04:58 AM
97CTR's Avatar
In a few weeks when I get my block back from Benson's I will be degreeing my JUN3's. Probably to far away to wait for my info, but I'll post it up when I do.
I have searched for specs also and have not had any luck.
Old Mar 31, 2006 | 05:08 AM
1 2 NV's Avatar
i hope to be assembling my block next week. got the shortblock done, waiting on the head.
i did degree the cams 2 years ago when i first got my 2L together. at +1, +1 the cams lined up perfectly to the crank. my head has been milled and my block has been decked. i just did it based on a 110 degree cam centerline though. dont know what the true actual centerlines were. those were specs given to me from a authorized JUN dealer if memory serves me right.
Old Apr 7, 2006 | 03:44 PM
dax-es's Avatar
Here are the specs that I was given by JUN when I bought their cams as measured on the primary lobes (4.6mm INT / 6mm EXH lift) -
Part# 1004M-H003 (INT)
- 1mm lift at 32° ABDC
- 110° lobe centre
- 1mm lift at 8° ATDC
Part# 1004M-H103 (EXH)
- 1mm lift at 8° BTDC
- 110° lobe centre
- 1mm lift at 32° BBDC
Old Apr 11, 2006 | 01:05 PM
Matty.'s Avatar
bump for some good info to know.
Old Apr 11, 2006 | 05:18 PM
jt-sport's Avatar
Default Re: looking for complete JUN 3 cam specs? (dax-es)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dax-es &raquo;</TD></TR><TR><TD CLASS="quote">Here are the specs that I was given by JUN when I bought their cams as measured on the primary lobes (4.6mm INT / 6mm EXH lift) -
- 110° lobe centre
- 110° lobe centre
- 1mm lift at 32° BBDC</TD></TR></TABLE>
whatta tiny cam 240 degree at 1mm?? i think it was supposed to be the primaries lobe right?
Old Apr 11, 2006 | 06:29 PM
B18C1_POWER's Avatar
anyone knows the spec's of the blox hsl COMPETITION series cams? I found the specs of the tuner series, let me know..
seelback
Sep 11, 2015 03:30 AM
Ekasey
Honda S2000
Aug 10, 2006 12:04 PM
jaM3s Bond
Oct 19, 2004 10:34 PM
