Anyone use bolts instead of studs on their intake manifolds?
Old Mar 30, 2006 | 05:21 PM
redman223's Avatar
Default Anyone use bolts instead of studs on their intake manifolds?
I noticed that when I put on the hondata intake manifold gasket and the skunk2 intake manifold, there was not enough "meat" on the studs to get them super tight. They are on there now, but I would feel more comfortable with longer studs, or bolts.
Is there any reason why bolts would not work? I am sure if I had my motor in front of me I could answer this question by simply looking at the engine, but I am several thousand miles away from my car...
If you have to use studs for some reason or another (maybe bolts will hit the runners, or something), where can I get longer studs?
Old Mar 31, 2006 | 10:59 AM
redman223's Avatar
Default Re: Anyone use bolts instead of studs on their intake manifolds? (redman223)
Nobody?
Old Mar 31, 2006 | 03:20 PM
redman223's Avatar
Also, would the length of the bolts matter? Instead of using the 3" or whatever studs could you just use a 1 1/2" bolt with a lock washer and some loctite?
Old Mar 31, 2006 | 07:02 PM
red civic standard's Avatar
when you purchase the outlaw engineering thermal gaskets, they provide bolts to use because of the same issue you are having. I have used them for two years with no problems.
Old Mar 31, 2006 | 07:05 PM
b19coupe's Avatar
I use RSX-S studs. I am running the Hondata I/M gasket sandwiched between two OEM gaskets, so I need all of the length that I can get.
Old Apr 1, 2006 | 10:33 AM
redman223's Avatar
Default Re: Anyone use bolts instead of studs on their intake manifolds? (b19coupe)
Thanks for the replies, I will probably go with bolts, since the RSX studs will probably cost like 2 dollars apiece, from Acura anyway.
Old Apr 1, 2006 | 12:17 PM
GSRCRXsi's Avatar
i just got extended IM studs from mcmaster. M8x1.25 part number 93210A030 http://www.mcmaster.com
i have plently of "meat"
Old Apr 1, 2006 | 12:29 PM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">I use RSX-S studs. I am running the Hondata I/M gasket sandwiched between two OEM gaskets, so I need all of the length that I can get.</TD></TR></TABLE>
Why do you have it sandwiched between the 2 stock gaskets? Just curious because all i used was the phenolic gasket itself and nothing else.
Old Apr 1, 2006 | 05:48 PM
Combustion Contraption's Avatar
Default Re: Anyone use bolts instead of studs on their intake manifolds? (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">Why do you have it sandwiched between the 2 stock gaskets? Just curious because all i used was the phenolic gasket itself and nothing else. </TD></TR></TABLE>
Same here.
Old Apr 1, 2006 | 06:20 PM
d16dcoe45's Avatar
Default Re: Anyone use bolts instead of studs on their intake manifolds? (LsVtec92Hatch)
I am actually using Allen head titanium bolts with titanium washers on my intake manifold. I will get some pics up. Frankly though, its not worth it--I am going to go back to the Honda studs....
Old Apr 1, 2006 | 08:24 PM
redman223's Avatar
Default Re: Anyone use bolts instead of studs on their intake manifolds? (d16dcoe45)
Thanks for that link, I think I will pick up a set of those extended studs.
Old Apr 1, 2006 | 08:30 PM
redman223's Avatar
Oh yeah, how many of the studs will I need, the motor is 5000 miles away, so I can't go look myself.
Old Apr 1, 2006 | 08:43 PM
GSRCRXsi's Avatar
like 10. i could be different depending on what motor you have, but bseries have 10
Old Apr 1, 2006 | 08:44 PM
GSRCRXsi's Avatar
Default Re: Anyone use bolts instead of studs on their intake manifolds? (GSRCRXsi)
oh and in your first post you said you cant get them super tight, they dont have to be super tight, only like 20 ft lbs
00civicnewb
Jun 7, 2024 04:50 PM
khmoe
Apr 4, 2008 06:59 PM
JFG Kevin
Aug 26, 2006 08:47 PM
project dc2
Mar 13, 2004 09:59 AM
