Signs of a bad radiator cap, thermostat? Cooling system help needed
sounds like it just had air in the system, if you dont want to take it back, to the bleeding procedure with the front end lifted.
if it isnt pissing out the overflow, you should be ok, if you have the means, pressure test the cap. i think youll be ok.
robbys89
May 13, 2009 12:02 PM
krysted9354
Feb 28, 2009 04:04 PM
