F/R GSR Disc Conv. -> Now rear popping noise when i break
Not so long ago I did a front and rear GSR disc conversion on my EG. And just yesterday for some reason when i'm breaking I hear somewhat of a popping noise.
At first I thought it might be the tire, but after letting it roll without pressing on breaks I didn't hear it. So then I would step on the brakes lightly, and you can hear somewhat of a popping noise comming from the left bottom side. Anyone have any idea what it might be?
Sounds like one of the bolts are coming loose. I would recheck all the bolts for the trailing arm, and if you see one coming loose take it off, put some lock tite on it and put it back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Sounds like one of the bolts are coming loose. I would recheck all the bolts for the trailing arm, and if you see one coming loose take it off, put some lock tite on it and put it back. </TD></TR></TABLE>
Did that, they were all on tight. thanks for the response.
After looking more into it, it turned out to the the screws that the rotor has. They were missing, so each time I would hit the brakes it would shift it and make the noise.
The retaining screws in the rotor would not cause that. They are put there for assembly purposes only. The wheel holds the rotor tight to the hub.
Historyg
Jul 27, 2008 07:54 PM
