suggestions on how to up compression high enough to run stage2 cams wiht stock pistons
Old Mar 30, 2006 | 01:00 PM
DC2SIR-G's Avatar
* B A N N E D *
Default suggestions on how to up compression high enough to run stage2 cams wiht stock pistons
i ahve a jdm b18c 16:6 comp ratio. i know i can use flat face valves/pp head/ and thin headgasket to up my comp ratio but is it high enough to use cams like s2s2 without touching my pistons? suggestions? thanks
Old Mar 30, 2006 | 01:22 PM
ChaseIntegra's Avatar
Default Re: suggestions on how to up compression high enough to run stage2 cams wiht stock pistons (DC2SIR-G
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2SIR-G &raquo;</TD></TR><TR><TD CLASS="quote">i ahve a jdm b18c 16:6 comp ratio. i know i can use flat face valves/pp head/ and thin headgasket to up my comp ratio but is it high enough to use cams like s2s2 without touching my pistons? suggestions? thanks </TD></TR></TABLE>
With flat valves, milled head and thin headgasket it will be sufficient. If you mill the head though and use a thin headgasket I would really check clearances when putting it together
Old Mar 30, 2006 | 01:31 PM
B18C1_POWER's Avatar
16:6 ohh god!!! lol
Old Mar 30, 2006 | 01:38 PM
D-Rob's Avatar
16:6, huh?
That's 2.6666:1 compression. That certainly not enough to run the S2S2's...
Just kidding. But how the hell do you have 16:1 compression? What gas are you going to be running.
With compression like that, you need much, much larger cams that the S2S2's.
I sure hope you're kidding...
- Derek
Old Mar 30, 2006 | 03:46 PM
hayabusa160's Avatar
diesel fuel y0
Old Mar 30, 2006 | 04:22 PM
DC2SIR-G's Avatar
* B A N N E D *
sorry yo i meant 10:6 typo can i just use flat face valves+thinner head gasket along with the dual springs and ti retainers? i heard some1 on this board says i need to raise comp at least to 11:5 to run the s2s2 perfectly.. is this true?
Old Mar 30, 2006 | 04:43 PM
Runnerdown's Avatar
if you dont have 11.5 or more the car probably wont even start.
but seriously 10.6 stock is fine a bit more will just help make some more torque and hp.
Old Mar 30, 2006 | 07:10 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: (Runnerdown)
with the stock 10:6 comp ratio.. and if i use a thinner headgasket.. am i better off with the stage1 or stage2?
Old Mar 30, 2006 | 07:58 PM
vteczone's Avatar
or..since you have the 87.2mm stroke,u could use the ctr piston and u could easily yield approx 12.5:1 which is good for the stage 2..
Old Mar 30, 2006 | 08:01 PM
Baggy Spandex's Avatar
Default Re: (vteczone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteczone &raquo;</TD></TR><TR><TD CLASS="quote">or..since you have the 87.2mm stroke,u could use the ctr piston and u could easily yield approx 12.5:1 which is good for the stage 2.. </TD></TR></TABLE>
First of all, he wants to AVOID a piston swap, and second of all, CTR pistons arent all that great
Old Mar 30, 2006 | 08:18 PM
Dan Ruddock's Avatar
Default Re: (NAisBEST)
More important than the cr is the rest of the motor needs to have the breathing to keep up with stage two cams. Like a good header and big exhaust a big TB help too. I know a guy with 01 gsr with S2S2 cams with stock bottom end with all the breathing stuff including good head work and the car haul ***. Make the engine breath and it will work. Dan
Old Mar 30, 2006 | 08:20 PM
Default Re: (Dan Ruddock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan Ruddock &raquo;</TD></TR><TR><TD CLASS="quote">More important than the cr is the rest of the motor needs to have the breathing to keep up with stage two cams. Like a good header and big exhaust a big TB help too. I know a guy with 01 gsr with S2S2 cams with stock bottom end with all the breathing stuff including good head work and the car haul ***. Make the engine breath and it will work. Dan</TD></TR></TABLE>
good info dan people get too caught up in compression numbers, and forget what will really help them benefit the most
Old Mar 30, 2006 | 08:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">
good info dan people get too caught up in compression numbers, and forget what will really help them benefit the most </TD></TR></TABLE>
That is because cr is a easy thing for most novices to understand. Dan
Old Mar 30, 2006 | 09:41 PM
camlob's Avatar
Dan, I am thinking of putting crower 402a's in my JDM ITR. I was thinking of putting 403's. Will it be too aggressive? I am thinking of just putting a mugen head gasket. Will the head gasket be worth it? Or do you think I should go for the ctr pistons straight ahead? It will take three to four days to put in the ctr pistons which to me is a lot of downtime. I currently have a 5zigen stepped up header and a short ram intake.
Old Mar 30, 2006 | 11:17 PM
vteczone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">First of all, he wants to AVOID a piston swap, and second of all, CTR pistons arent all that great </TD></TR></TABLE>
arrgghhh..my bad,when i read the title of the thread just now..i went shiieett.lol..
i do agree ctr isnt that great,not much valve clearances too.
Old Mar 30, 2006 | 11:20 PM
rjay8604's Avatar
Well said.
jdm ek9 101
Sep 1, 2006 03:58 AM
TYPErCRX
Jul 15, 2006 01:03 PM
tomlinson619
Mar 21, 2006 08:14 PM
Nolan
Sep 15, 2004 05:29 AM
craka
Jan 27, 2003 05:01 PM
