B18c5 build - need reliable #'s
Old Mar 30, 2006 | 12:03 PM
TPB's Avatar
TPB
Default B18c5 build - need reliable #'s
I'm asking this because I keep getting different results on the various online compression calculators. The engine build includes new rod bolts, ringset, gaskets, 3 angle valve job, etc.
<U>Scenario 1:</U>
B18c5 block bored .25 os
OS PCT pistons
Skunk2 pro 1 cams
stock head
<U>Scenario 2:</U>
Same as above with .015 milled off the head
This is a track only car (road racing). Once I know the CORRECT compression figures, then I'll be able to determine the best octane to use.
Thanks for any help.
Old Mar 30, 2006 | 02:36 PM
97L-esVeeTeg's Avatar
Default Re: B18c5 build - need reliable #'s (TPB)
The numbers i get assuming you are using stock HG (.026) and valves are....12.6 for first scenario and around ~12.9 for the second scenario
Old Mar 30, 2006 | 02:46 PM
TPB's Avatar
TPB
Default Re: B18c5 build - need reliable #'s (97L-esVeeTeg)
Yes, stock HG and valves.
How did you calculate the cr's? I'm just trying to determine a good, reliable method that gives me the correct answer.
Thanks
TPB's Avatar
TPB
edit: oops.
Ephekt
12
Aug 7, 2013 08:15 PM
Tenji
May 17, 2006 08:29 AM
redhanyo
12
Apr 15, 2006 07:39 PM
Toda Party
Sep 10, 2002 04:42 AM
