ABS Light after axle change !?
Old Mar 30, 2006 | 11:36 AM
Marlon88's Avatar
Default ABS Light after axle change !?
Hello guys.
I searched about this and I came up with nothing !
I just finished up installing some Drive shaft shop Stage 5 axles in my car , I ordered them with ABS rings.
When I went for a drive to see that everything is ok the ABS light came on after about 3 miles of driving , I came home and took off the both front left and right sensors anf gave them a good clean up ( They were dirty ) then I went and took off the negative terminal on the battery for 15 seconds to reset the ABS ECU , The ABS light is still there and I can`t make it to go off !! I also unpluged all the fuses that is located in the ABS fuse box near the engine .
Now I read the codes and it gave me a code 11 , 12 and 36 wich are
Code 11 : Right front wheel sensor. (open/short to body ground or short to power)
Code 12 : Right front wheel sensor. (electrical noise or intermittent interruption)
Code 36 : Right rear outlet solenoid.
Can some one please help me out
I don`t know what to do
Everything was fine before I changed the axles
Old Mar 30, 2006 | 11:47 AM
JjuuN R's Avatar
hmmm, did you actually test to see if the abs does in fact work still?? find a vacant lot with a lot of room, test it out and let us know.
i can't answer your question but i have heard of this with people using aftermarket axles
Old Mar 30, 2006 | 11:50 AM
Dave_B's Avatar
Sounds like you may have gotten one with out the ABS rings, check to make sure they have them, or see if you can get a pic of the ones that do have it.
Old Mar 30, 2006 | 12:05 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you may have gotten one with out the ABS rings, check to make sure they have them, or see if you can get a pic of the ones that do have it.</TD></TR></TABLE>
I agree, you said you ordered ones with the rings but did you ensure that they were actually there?
Old Mar 30, 2006 | 12:16 PM
Hooch'n's Avatar
Yep, this will happen without the rings that go around the out side of the axle....
Cycler Rings? i think (sp?)
Old Mar 30, 2006 | 12:29 PM
typer2k1's Avatar
if you do have the abs rings, check the teeth on the rings themselves. I was having a similar problem, and come to find out the teeth on one of the rings looked like they were hit with a hammer causing the sensor to go off.
Old Mar 30, 2006 | 03:49 PM
Marlon88's Avatar
Default Re: ABS Light after axle change !? (Marlon88)
The Rings are there , they were installed from Drive shaft shop .
I cleared out the codes and went for a drive agian , I tryed to stop hard and the wheels lockd so the ABS is not working . Then after 1 mile of driving the ABS light went on again , got home and pulled the codes , this time it got me only 1 code that is code
code 12 : Right front wheel sensor. (electrical noise or intermittent interruption)
I don`t know what else to do !!
I did like typer2k1 told me to do and checked the teeths and on one of the teeths there is a little ding on it !! could this be the problem ? what did you do to the damaged tooth typer2k1 ?
Thanks very much for your help guys
I realy like to keep the ABS system working
Old Apr 2, 2006 | 07:50 PM
typer2k1's Avatar
sorry for the late reply, since i got the axel from autozone i took it back and got an exchange, i made sure this one didnt have any dings on the teeth, installed it and had no more problems
good luck
Agent Daimon
Nov 8, 2010 12:03 PM
DUHC
Aug 21, 2009 11:19 AM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
e jay one
May 15, 2006 12:07 PM
