shift linkage pin
Old Mar 30, 2006 | 11:32 AM
NSfit's Avatar
Default shift linkage pin
how do i get this pin out og the shift linkage iv tried hitting it with a screwdriver and hammer and that didnt work anyone have any tips
Old Mar 30, 2006 | 11:35 AM
the stock cx's Avatar
Default Re: shift linkage pin (NScivic)
you need a punch of the same size,if you want it to come out easier. any other type of punch will work but you gotta get a lot of good hits with the hammer. and spray honda lube or some sorta of lube it should come right out. hope that helps.
Slopoke's Avatar
Use a punch and a big hammer.
It will come out, just keep working at it.
Old Mar 30, 2006 | 11:42 AM
jadugartir's Avatar
I avoid the bitch pin like the plague, i prefer to never HAVE to take it out, but if i did, i would use a punch and hammer, and just keep banging on it, also i heard that you can use an ac compressor bolt to knock it out, because its just the right size, ive never done it but its worth a try.
Old Mar 30, 2006 | 12:36 PM
mike1114's Avatar
Default Re: shift linkage pin (jadugartir)
WOw.....I cannot believe how many people have problems with this!
It takes me like 5 seconds to get this out EVERY TIME.
Just get a punch that can fit through the hold and pound on it with a hammer. About 5-6 whacks is all it takes and I'm a little guy
Old Mar 30, 2006 | 01:13 PM
littleredcivic's Avatar
are you punching the right spot? from the marks on your picture, you are not punching the pin, you are hitting the joint. the roll pin is the one closest to the transmission case.
Old Mar 30, 2006 | 01:23 PM
fhtfhatchy's Avatar
mine was replaced with a thru bolt, i dont know if thats good or bad...
Old Mar 30, 2006 | 01:39 PM
92hatchling's Avatar
Default Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">are you punching the right spot? from the marks on your picture, you are not punching the pin, you are hitting the joint. the roll pin is the one closest to the transmission case.</TD></TR></TABLE>
nortrop's Avatar
Default Re: (fhtfhatchy)
from the looks of it, you have been beaing the crap out of the big pin. You wanna be punching out the smaller pin.
Old Mar 30, 2006 | 02:12 PM
mattssi's Avatar
air compressor- air hammer. 2 seconds flat. If that isn't a option, then go with a big hammer. And hit the pin that actually comes out. The one on the shaft from the tranny.
Old Mar 30, 2006 | 02:21 PM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fhtfhatchy &raquo;</TD></TR><TR><TD CLASS="quote">mine was replaced with a thru bolt, i dont know if thats good or bad...</TD></TR></TABLE>
im surprised you havent complained of any slop in your shifting... a bolt causes lots of play in the shifter.
To the original poster, if you can... get your hands on an 8mm pin punch (i got a few from mcmaster). they work great!
If not, a crude way is to use one of the bolts that hold on the AC compressor, they have a taper in the end of them that fits nicely in the shift pin hole.
hope this helps
Old Mar 30, 2006 | 03:19 PM
efb16's Avatar
Default Re: (B18EG6)
If you dont have a punch, I have used a nail before. you just have to make sure the nail is small enough to fit thru the sleve that the pin is in. and just wack at the nail with a hammer.. It does take some time, specailly if your laying on your back with the car on jackstands.
Old Mar 30, 2006 | 03:21 PM
NJcoupe's Avatar
Default Re: (efb16)
use an air hammer.
Old Mar 30, 2006 | 03:22 PM
efb16's Avatar
Default Re: (efb16)
after looking at that picture it does look like you have been smacking the shaft that comes out of your tranny that your shiftlinkage connects to. I hope you havent that might be a bigger problem than not being able to get the pin out.
Rico's Avatar
Get a punch set from Sears or if you cant get to one I've used a 9/16 bolt before to hit it out...
Old Mar 30, 2006 | 04:19 PM
CardDealer's Avatar
Banned
Default Re: (Rico)
Modified by CardDealer at 2:43 PM 11/16/2006
Old Mar 30, 2006 | 04:22 PM
wallacecrx's Avatar
do a search and youll know
Old Mar 30, 2006 | 04:40 PM
Timmay's Avatar
Default Re: shift linkage pin (wallacecrx)
air hammer works good if you have a nice compressor
i use a punch and hammer almost ever time
Old Mar 30, 2006 | 05:08 PM
b16pwrcrx's Avatar
Default Re: shift linkage pin (Timmay)
i use the ac bolt, that 12mm that holds the compressor to the bracket, they work great for punches, like 5 good hits and its out all the time. the bold is a perfect fit.
Old Mar 30, 2006 | 05:45 PM
civiccoupe94's Avatar
just took one out today.. 20 minutes.. 97 civic dx... screwdriver and a hammer
Old Apr 1, 2006 | 07:13 PM
NSfit's Avatar
Default Re: (civiccoupe94)
got it guts i guy i had to resort to the grinder but its out
Old Apr 1, 2006 | 07:24 PM
x_outlaw_x's Avatar
get a 12mm bolt and beat on the head with the threads touching the pin, it takes like 10 seconds my way
Old Apr 1, 2006 | 07:28 PM
SkRiBLaH's Avatar
Default Re: (x_outlaw_x)
thats stupid. a trip to home depot would save your shift linkage. 1/4 punch is what you need. (8mm)
Old Apr 1, 2006 | 07:48 PM
x_outlaw_x's Avatar
the threads on a 12mm bolt is 8mm thats what makes it work so great
Old Apr 1, 2006 | 08:17 PM
Z3120's Avatar
Default Re: shift linkage pin (mike1114)
Use the right tool (punch) or make one from a short screw driver ( make sure the shaft is about the same size as the pin). Make sure you are hammering on the right one.
