throttle body
Old Mar 30, 2006 | 11:14 AM
na91hatch's Avatar
Default throttle body
what it do? ive got an idea and im pretty sure it will work, but just checking. i have a 91 w/ d15. can i use the stock throttle body off an EG mpfi d15? if so, my plans would then be to change the dpfi in my car to mpfi. Wouldn't my car be running fine if i used a civic si ecu w/ some modifications to the wiring harness? any help would be appreciated.
Old Mar 30, 2006 | 11:30 AM
Redline130's Avatar
Default Re: throttle body (na91hatch)
Do you mean throttle body, or intake manifold? You can't just use the EG throttle body on your DX. If you want to do a DPFI to MPFI conversion, then yes you will need an 88-91 Civic/CRX Si/EX ecu and do some wiring additions.
Old Apr 1, 2006 | 01:14 PM
na91hatch's Avatar
Default Re: throttle body (Redline130)
then would an intake manifold off of a dohc zc motor bolt on?
Old Apr 1, 2006 | 03:44 PM
Redline130's Avatar
I'm pretty sure it won't.
honda305
Sep 3, 2006 04:48 PM
SiMateoAko
Aug 11, 2005 02:52 PM
