zc diff in si trans
Old Mar 30, 2006 | 10:19 AM
EF9ZC's Avatar
Default zc diff in si trans
Ok i want to know if i can put a lsd from a zc in a si transmission. Anyone know if this is posible?
Old Mar 30, 2006 | 12:45 PM
Tyson's Avatar
Default Re: zc diff in si trans (EF9ZC)
will be just fine.
just as long as you have the right axles for the bigger diff opening. and make sure the final drive gear is the right one. you can swap the ring gear between the diffs too.
rel
Jul 25, 2010 01:37 PM
U5EL355
Oct 18, 2006 08:55 AM
1990CrxSi
Jul 11, 2002 05:57 AM
