Suspension & Brakes Theory, alignment, spring rates....
brake and knuckle help...
Old Mar 30, 2006 | 07:20 AM
the soL that could's Avatar
Default brake and knuckle help...
i have a set of integra front brake assembly off a GS-R and i was wondering what parts could i used from my 94 del sol S stuff... such as:
the wheel bearing
washer (opposite side of rotor) part #1 in this link http://www.hondaautomotivepart...UCKLE
ball joints #4 and down on that link
metal mud gaurd.
i'm asking because that gsr front set has been sitting in JDM land for like 10 years lol. everything seems rusted to ****. so i would like to know if i can use the parts of my EG and just mix them up with that gsr set. TiA
Old Mar 30, 2006 | 08:10 AM
Default Re: brake and knuckle help... (the soL that could)
bump for some answers
Old Mar 30, 2006 | 09:14 AM
94eg!'s Avatar
#1 Super Guy
Loved
The 94 Del Sol VTEC will have all the same part numbers as the Integra GSR (except calipers are slightly different).
Compare the 94 Del Sol VTEC part numbers with your model Del Sol part numbers to see which parts are the same and therefore cross-over...
Old Mar 30, 2006 | 09:37 AM
Default Re: brake and knuckle help... (94eg!)
freaking computer @ work will not let me access hondapartsdeals.com
Old Mar 30, 2006 | 10:10 AM
94eg!'s Avatar
#1 Super Guy
Loved
use slhondaparts.com or hondaautomotiveparts.com
Old Mar 30, 2006 | 10:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">use slhondaparts.com or hondaautomotiveparts.com</TD></TR></TABLE>
no part #'s... and san landro not working for me either. hondaautomotiveparts.com only got reference #'s =/
Old Mar 30, 2006 | 12:46 PM
94eg!'s Avatar
#1 Super Guy
Loved
The reference numbers on HondaAutomotiveParts.com are just as helpful for crossreferencing parts as long as you compare them with other parts on their website only. Just open a different window for each vehicle model & compare all the numbers side by side. Then you can tell what parts are the same & what are different.
I compared all the reference numbers from the "knuckle" page of the 94 Del Sol VTEC with the 94 Del Sol S and found that the only part numbers (reference numbers) that differ, are the knuckles themselves. The balljoints, axle rings and other parts are all identicle for both models...
Next I compared the parts in the "front brake" category. It turns out that almost every part in this section is different part numbers. I'm guessing that some parts will still cross over (mabey mud guards & hubs), but you will have to test them out to be sure. If you really want good wheel bearings, I suggest you just buy new ones & install those (instead of trying to use your old ones from the Sol). If the bearings don't cross-over properly, that could be dangerouse.
Old Mar 30, 2006 | 12:47 PM
i downloaded mozilla just to use @ work for that ... lol the wheel bearings do not work. from the 94 del sol S to the GS-R
Old Mar 30, 2006 | 01:13 PM
slammed_93_hatch's Avatar
the wheel bearing, hub, and dust sheild are all different.
the Hub's can be cleaned with a wire brush, and "rust remover", i'd replace the wheel bearings, they themselves aren't to much money, but most shopes LOVE to charge 70 bucks a side to install them.
kelvar13
Oct 5, 2004 07:36 PM
JSPECHB
Jun 17, 2003 11:36 AM
91hatchnewb
Apr 28, 2003 01:54 PM
ill phil
Jan 5, 2003 09:44 AM
