Which car has a F20b engine?
Old Mar 30, 2006 | 02:27 AM
djnikko's Avatar
Default Which car has a F20b engine?
As the title says, I need to get hold of a crank pulley with no PAS in the UK, just wonderd if someone can tell me the spec of the car that comes with a f20b engine. I can then do a parts search and end up with the right part for the right engine
e.g. 2.0i, 1988 Accord, EX?, EXI? DX? etc etc
Thanks
Old Mar 30, 2006 | 04:37 AM
pentaq's Avatar
Default Re: Which car has a F20b engine? (djnikko)
F20B3- Accord Aerodeck (Wagon) 1994
Old Mar 30, 2006 | 06:05 AM
djnikko's Avatar
Default Re: Which car has a F20b engine? (pentaq)
Thanks for the reply Can anyone confirm this vehicle has a single pulley? or no PAS?
Old Mar 30, 2006 | 08:26 AM
mgags7's Avatar
they (at least every one i have seen) have power steering
the non power steering pulley you want is the h22 euro r pulley
Old Mar 30, 2006 | 11:24 PM
djnikko's Avatar
Default Re: (mgags7)
Do you know which model these are found on?
Thats handy as I live in Europe
Old Mar 31, 2006 | 07:59 AM
mgags7's Avatar
they came in accord euro R models, which i believe were in japan only
try the accord type R or something over there, i believe the engine code is H22a7
EDIT: yeah like i could have guessed, you obviously did not look in the FAQ for the motor catalogue thread https://honda-tech.com/zerothread?id=641555
Old Mar 31, 2006 | 08:38 AM
Prelude SIR-T's Avatar
jdm 97-01 accord SIR-T has the f20b and it does not have a power steering pump because the car has electric power steering. this is the crank pulley you <U>WANT!!</U> (good luck trying to find one) hope this helps if you have any other questions about f20b let me konw
Old Nov 25, 2009 | 07:34 AM
driver acoord's Avatar
New User
i want to swap intake from H23A to F20B3 accord coupe 1997,do you know som stuff about this-advices
Old Nov 25, 2009 | 08:34 AM
92civlude's Avatar
Im pretty sure the A7 Accord Type R has a power steering pump. The Euro-R does not, its a single pulley. hmotorsonline has them for $90.
Old Nov 25, 2009 | 12:33 PM
GlassJAw's Avatar
Chassis Models for the SiR-T & Euro R Accords are as follows
CF4 = SiR-T Accord / Torneo F20B Manifactured between 97-02
CL1 = Accord / Torneo Euro R H22A Manifactured between 00-02
Both have EPS Steering systems without the extra pulley. Both these cars are available in Ireland so surely someone has wrecked / salvaged one there??
fuse1369
Nov 4, 2009 08:40 AM
fredskidoo
Aug 30, 2008 09:07 PM
randrade24
Mar 15, 2007 08:09 AM
chrisfletcher
Jan 11, 2007 05:04 PM
