WTB hasport ek motor mounts
No I don't have any mounts, but...
If you are putting any B-series into a 96-00 chassis there are really only 1.5 mounts that are compatible between B and D. If you are talking about the stock rubber chassis mounts then the EK dohc and sohc all use the same ones but the engine brackets are not the same. You can use the top tranny bracket and the upper driver side bracket from your D-series. But you need a 99-00 Si rear tranny bracket and upper block bracket (bolts under the timing cover). Any hydro B-series front tranny bracket will work. If you want to keep your stock a/c w/o changing compressor get a P54 or P7J a/c bracket.
There is no need for expensive Hasport kits to install a B-series into an EK it can be done with combination of stock stuff. Unless you get a totally smoking deal on the custom stuff.
yes i know all of that...i asked if you had hasport mounts cause i will tear the stock mounts with 700 hp......let me know if anyone has the hasport ek mounts thanks!
TheCrimsonGhost666
Mid-Atlantic (Sales)
Dec 17, 2009 08:24 PM
JDM son!
Mar 11, 2009 02:48 PM
