will this work aight?
Old Mar 29, 2006 | 11:00 PM
CivicBlack's Avatar
Default will this work aight?
My 96 civic coupe is lowered 1.9" in front and 1.7" in the rear.
will i be okay with 16" wheels with 205 50 16 size tires?
Old Mar 30, 2006 | 05:49 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: will this work aight? (CivicBlack)
No. Get 205/45-16.
Old Mar 31, 2006 | 09:31 AM
CivicBlack's Avatar
Default Re: will this work aight? (nsxtasy)
is there a reason it won't work? Just wondering cause i already placed the order and those are the size the wheels are coming with.
Old Mar 31, 2006 | 06:04 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicBlack &raquo;</TD></TR><TR><TD CLASS="quote">is there a reason it won't work?</TD></TR></TABLE>
Yes. They're too big in diameter (about 2.7 percent larger than stock) and they will probably rub on the wheel wells or fenders, especially on a lowered car.
205/45-16 is actually slightly smaller in diameter than stock (roughly 0.8 percent) and shouldn't rub.
General rule of thumb to avoid rubbing: don't get tires wider than 20 mm wider than stock (those aren't), and don't get tires whose outer diameter is more than 1 percent larger than stock (those are).
Old Mar 31, 2006 | 10:51 PM
CivicBlack's Avatar
alright thanks i'll see how they do when i get them. . if i don't like it i'll get the size you suggested thnx
Old Apr 21, 2006 | 05:23 PM
CivicBlack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
I decided i didn't want to chance it. So im taking your advice. I cancelled the order today and im going with 205/45/16's instead.
Old Apr 21, 2006 | 09:01 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicBlack &raquo;</TD></TR><TR><TD CLASS="quote">I decided i didn't want to chance it. So im taking your advice. I cancelled the order today and im going with 205/45/16's instead. </TD></TR></TABLE>
mikeycivic
May 22, 2009 01:27 AM
jordanitr
Apr 17, 2007 06:02 AM
Jason84
Acura TL, RL & ZDX
Dec 21, 2006 02:46 PM
ejcivicdee
Jun 2, 2006 06:16 PM
1Tym
Aug 24, 2004 03:39 PM
