F*$*&*% Idle
Old Apr 3, 2002 | 05:37 PM
H23 Power's Avatar
Default F*$*&*% Idle
ok....my car wont idle...ever since I put in the F23 engine...it wont freakin idle
it goes from 1,000 to 1,500 rpms constantly...up down up down...blah blah
I had a check engine light, code 14, intake air control valve...i checked to make sure it was seeing power...then replaced it...NOTHING, same dumb ****...
sorry, I'm pissed...I have traced wiring everywhere...I have clue what to do
Old Apr 3, 2002 | 05:38 PM
Accord94DX's Avatar
Default Re: F*$*&*% Idle (01GSR)
knock sensor?
edit: a question mark.
[Modified by Accord94DX, 6:38 PM 4/3/2002]
Old Apr 3, 2002 | 05:39 PM
H23 Power's Avatar
Default Re: F*$*&*% Idle (Accord94DX)
how does that relate to it? i'm confused..
I wired the knock sensor up to the ecu...*shrugs*
Old Apr 3, 2002 | 05:48 PM
Accord94DX's Avatar
downright koo-koo i know, but a friend was changing engines in his prelude h23a1(blown) h23a1(good) and the knock sensor was fried on the new one. The car would start, but wouldnt idle. (sound familiar?) He swapped out knock sensors and presto! It idled. Maybe it was an act of god, i dunno.
Old Apr 3, 2002 | 06:36 PM
scrubachu's Avatar
could be IAC or IAT. IAC=Idle Air Control Valve, happens on mine sometimes. Or, IAT=Intake Air Temp Sensor. most likely IAC though, or vacuum leak. check all your vacuum lines.
Old Apr 3, 2002 | 06:43 PM
Gennady's Avatar
New User
Default Re: F*$*&*% Idle (scrubachu)
Its definetly a sensor problem.
I wasnt aware our cars had an IAT....where is it?
Old Apr 3, 2002 | 06:45 PM
Accord94DX's Avatar
Default Re: F*$*&*% Idle (Wont be beat)
i think the IAT is on f23s.
Old Apr 3, 2002 | 06:47 PM
Gennady's Avatar
New User
Crap!! I know of a mod that will make any car with an auto and an IAT shed 0.5 off there 1/4 time.
Old Apr 3, 2002 | 06:49 PM
Accord94DX's Avatar
Um. Explain plea?
Old Apr 3, 2002 | 06:51 PM
Gennady's Avatar
New User
In due time my friend...
Old Apr 3, 2002 | 06:52 PM
H23 Power's Avatar
F22's also have IAT
its NOT the IACV...i just said i replaced it... does it sound like it could be a vacum leak? i've checked the hoses 18 times...but the F23 vacum setup is way diff than the F22...
anyone have a 6th gen helms that could scan me the vacum lines page?
Old Apr 3, 2002 | 06:53 PM
Gennady's Avatar
New User
Where is the IAT on F22a's
Old Apr 3, 2002 | 07:02 PM
H23 Power's Avatar
drivers side of the intake manifold...
Old Apr 3, 2002 | 07:04 PM
Gennady's Avatar
New User
Would you mind posting a pic from hondaautomotiveparts.com and pointing out a # for me please.
is on me.
Old Apr 3, 2002 | 07:09 PM
H23 Power's Avatar
its not visible from their pics...I take a pic in a while...if I feel like working on my car anymore tonight
Old Apr 3, 2002 | 07:14 PM
Gennady's Avatar
New User
Cool
Old Apr 3, 2002 | 09:59 PM
H23 Power's Avatar
lx...but yours should be near it anyway
Old Apr 3, 2002 | 10:01 PM
H23 Power's Avatar
ok...as far as my problem...I really need to see a vacum diagram for a 6th gen 4 cylinder...
maybe i'll just stop by the dealer and take a pic of one under the hood...lmao
it anyone has a helms please lemme know
Old Apr 3, 2002 | 10:07 PM
Gennady's Avatar
New User
Hmmm...cool, thanx. Ill see what I come up with.
Old Apr 4, 2002 | 08:30 AM
4doorH22's Avatar
Fast idle thermo valve or something. I'm getting my F and H motors mixed up, as the placement of this valve is different on each motor. It just allows the car to idle higher when the coolant is cold. There should be a small hole somewhere before the throttle plate. The Helms says with the engine on, this hole should be under vacuum or suction. If not, replace fast idle thermo valve or something.
Eh, nevermind all this. I'll quote the Helms when I get home from work.
Old Apr 4, 2002 | 08:42 AM
H23 Power's Avatar
Default Re: F*$*&*% Idle (4doorH22)
i replaced the throttle body (the fast idle thermo valve is attached to it on the F23) so I don't think that is it...
i had it hold rpms around 600 once...but it felt like it was going to die...i was messing with the vacum lines...so I'm pretty sure thats what it is...but I couldn't figure out much more than that.
[Modified by 01GSR, 11:43 AM 4/4/2002]
Old Apr 4, 2002 | 08:47 AM
John's Avatar
New User
My car was doing the same thing, and when I read and reread through my Helms, it seems that the problem may be due to a heavy electrical load. So what does that mean? Either a faulty electrical connection somewhere or the alternator. When I have the stereo on, and my lights on, and I come to a light and let the car idle, that's why my idle will start fluttering... I just never got around to actually finding the source of this nuisance...
Old Apr 4, 2002 | 09:04 AM
thenick's Avatar
Default Re: F*$*&*% Idle (DunReit)
http://hondasociety.com/board/showth...highlight=idle
Old Apr 4, 2002 | 09:15 AM
H23 Power's Avatar
Default Re: F*$*&*% Idle (ixiblindixi)
Old Apr 4, 2002 | 09:21 AM
SOHCArchangel's Avatar
the fast idle valve is the problem, remove it, plug the hole under the t/b and re-route the coolant
