axle problem
did a b16a swap into my 90 crx and i am having a problem with the front right axle.i tried the 90-93 integ axle and it didn't seem to work like it was to long and too tight. so i got a 89 integ axle on it right now and it seems to bind still and this one is shorter.it seems to bind when i go around a right turning corner or if i hit a good dip in the road. any suggestions on the problem or what axle i need to use?
He said right axle though,,so wouldnt that be passenger side where there is no halfshaft..? But yeah if it is the halfshaft side make sure you have a 90-93 integra halfshaft if you want to use the 90-93 integra axle..Maybe you have the 90-91 sir halfshaft and thats why it wont work..But if thats the case you have to use the 86-89 integra axle with the 90-93 integra inners ,so you have all the parts already if you need to do that..Or you can always convert to 90-93 integra halfshaft..Also,did you remember to remove he littler dust rings from inside the hub..?
h22ame
Mar 3, 2004 05:00 PM
