SPUN BEARING..WTD?
Old Mar 29, 2006 | 08:22 PM
Projct_hatch90's Avatar
Default SPUN BEARING..WTD?
ok i just got this 89 hatch, it turns over and everything...well here is the story. bought it from a friend who lost the plug to the oil pan, drove it wwith out oil. now it sounds like a machine gun, turns over and runs just knockes really bad. if it is a spun bearing how can i fix it and how do i get to it?
Old Mar 29, 2006 | 09:07 PM
bks84's Avatar
Loved
replace the engine
Old Mar 29, 2006 | 09:31 PM
cptengineer's Avatar
Default Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">replace the engine</TD></TR></TABLE>
Old Mar 29, 2006 | 10:47 PM
ExospeedAMcrx's Avatar
Default Re: SPUN BEARING..WTD? (Projct_hatch90)
motors with spun bearings are usually not recommended to be rebuilt. You can have damage to the main journals and the crank.
I'd rather start from scratch that trying to fix that block. Its cheaper and better for peace of mind to use a fresh good block to use.
Old Apr 3, 2006 | 07:39 AM
what about jsut buying engine motor bearing kit???
Old Apr 3, 2006 | 07:48 AM
formby's Avatar
just buy a crank kit [160+/-] and youll be fine...
.if you dont want to spend the cash involved in a slight rebuild then buy another used long block.....but then its just another 115k+ engine instead of a rebuilt bottom end...
go to a reputable IMPORT oriented shop [they shoud know what a b series is whit out a hiccup} and do the rubuild. i dont know why its not a good idea to rebuild. this is the first time ive heard about it...
Old Apr 3, 2006 | 10:47 AM
I Have an STD's Avatar
wrenchin'
Default Re: (formby)
cause if the bearing is spun, the crank is SHOT. honda cranks dont like to be cut.
please just get a new shortblock. they are no more than like 50-60 bucks at the junkyard
Old Apr 3, 2006 | 10:48 AM
Han Solo's Avatar
ur friend drove the car without oil????? thats stupid 101. but yea id start over from scratch
Old Apr 3, 2006 | 04:55 PM
formby's Avatar
ok...
johnnyonth3spot
18
Sep 5, 2009 08:24 PM
xxmastermindxx
May 6, 2007 09:17 AM
civickiller
Aug 7, 2004 03:00 PM
Muckman
May 17, 2004 08:33 PM
Quetzolcotl
Sep 3, 2003 09:27 AM
