NEED SERIOUS WIRING HELP NOW!!!!!
Old Mar 29, 2006 | 07:12 PM
og_hatch_90's Avatar
Default NEED SERIOUS WIRING HELP NOW!!!!!
ok ive been searching on the web for hours now and nothing is coming back that helps. im doing a b18a1 swap into my 90 civic base model hatch TOMORROW!!!. DPFI-MPFI wiring seems to be easy to find info on...BUT, im using OBD1 plugs/wires to bypass the injector resistor box.
i need info about DPFI-MPFI wiring using OBD1 plugs and no resistor box. what i need to know is, what color wires to connect to what other color wires..and what pins on the ecu harness to switch around..as well as any other useful info on this. I NEED ANSWERS ASAP PLEASE!!!!!!
Old Mar 30, 2006 | 05:46 AM
NJcoupe's Avatar
same exact way as wiring from DPFI-MPFI. but instead of the colors matching, use the opposite ones. I had to do that w/ a friends, turned out the injectors were staying open. you can use obd0 plugs. and still bypass the resistor box.
90goldhatch
Jun 15, 2007 03:38 PM
dephtone
Feb 26, 2007 12:46 PM
BoostinEm1
May 1, 2006 06:34 PM
og_hatch_90
Mar 30, 2006 04:01 AM
90_Civic_Hatch
Jun 13, 2002 09:00 AM
