center bore on the RSX
Does anyone know the center bore on the RSX because im lookin at rims that 17 inches by 7.5 inches and a offset of 48 mm. i need to make sure they fit properly
If the rims have a larger center bore, go get hubcentric rings to make them fit properly. Aluminum rings can be had for less than twenty bucks for a set of 4.
One tip I wish I knew last summer: Superglue the rings to the wheels so that they're easier to remove when you change wheels.
businessmanph
20
Jul 27, 2006 04:17 PM
