Crazy Tach Problem w/ Tachometer
Well guys i just swapped my GSR cluster in my 95 Civic..
everything is working right except..
the turn signals and the TACH
The Tach works fine up to 3k and then stops..... and then when the rpms come back down it will work just fine... but it wont go above 3k... also when i go WOT it goes back down... ??!?!??!??!!?
I just took out my stock EX/SI cluster and the tach was working 100% fine... let me know... thanks CHase
I need to find out what is wrong
PLEASE help
Did you own the GSR Cluster..... In other words, did you see it function 100% Correctly before you bought it.
I've heard of peeps getting ripped off, bought a cluster with a short/malfunction in it.
mugenhatch92
Mar 30, 2006 12:26 PM
