Suspension & Brakes Theory, alignment, spring rates....
Weird noise... including video (from fenderwell)
Old Mar 29, 2006 | 05:59 PM
nickzed20's Avatar
Default Weird noise... including video (from fenderwell)
attention: profanity in the video, lmao.
http://videos.streetfire.net/v...7.htm
seems to be comming from my front fender well... whenever i brake hard or hit a bump i get this noise. i was thinking the tire is rubbing but my friend says it doesnt sound like that... maybe he doesnt know what hes talking about.
anyways, any input would be cool.
Modified by nickzed20 at 10:33 PM 3/29/2006
Old Mar 30, 2006 | 07:02 AM
nickzed20's Avatar
Default Re: Weird noise... including video (nickzed20)
no one knows?
Old Mar 30, 2006 | 06:17 PM
nickzed20's Avatar
buzzumptuous
Old Mar 31, 2006 | 05:56 AM
spunkysandoval's Avatar
sounds like some rocks were bouncing around in your fender well. Noises are pretty tought to diagnose when you have the car, I cant begin to explain the difficulty of doing it through a description and a vague video. sorry
Old Mar 31, 2006 | 06:13 AM
Function7's Avatar
The suspension needs to be checked. There's a good chance there is enough play in the front lower control arm (probably due to bad bushings) for the front wheel to move backwards (or forward) enough for the tire to rub against the fender well.
Does the car pull to one side when you brake and the opposite when you accelerate? If it does, it's a confirmation of this movement.
-A
Old Mar 31, 2006 | 07:25 AM
nickzed20's Avatar
Default Re: Weird noise... including video (Function7)
nope... it pulls a bit but thats because i need an alignment. the bushings are all new energy suspension bushings!
i just want to know if it sounds like rubbing or not. its definately not a rock.
Trackready
Honda Civic (2006 - 2015)
Apr 27, 2013 08:09 PM
panchlow
May 8, 2011 07:18 PM
nickzed20
Mar 31, 2006 05:44 AM
MyLittleRedCar
Oct 20, 2003 10:48 PM
nek0
Jun 13, 2003 07:32 PM
