preventing the LCA bolt from breaking / stripping?
Old Mar 29, 2006 | 04:35 PM
ekcivic9's Avatar
Default preventing the LCA bolt from breaking / stripping?
Hey guys
Im about to do a suspension install, and I was searching and reading misc. info.
I realized that a lot of guys have stripped / snapped the LCA bolt . I would REALLY love to avoid this problem as it is a big hassle. I do not have money to buy new LCA's or bushings atm. I need the install to go through as smoothly as possible
My civic has been down south all its life, so I hope there isnt too much corrosion down by the LCA bolts
Tonight, I went out and bought a can of PB Blaster. I was thinking if I sprayed some on tonight, and sprayed on some tomorrow night, I should be ok by Friday afternoon?
thanks
Old Mar 29, 2006 | 04:59 PM
96Civic_Coupe's Avatar
i would also like to know, might be getting some omni lca's soon.
Old Mar 29, 2006 | 05:48 PM
sohc'd upEJ8's Avatar
Default Re: (96Civic_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">i would also like to know, might be getting some omni lca's soon.</TD></TR></TABLE>
x2
Old Mar 29, 2006 | 05:51 PM
imm0rt41's Avatar
Well if the bolt has seized it doesn't matter since it is hard as hell to get them off. Just try a big freaking breaker bar and if it strips you'll have to cut it out and get new bushings and bolts...nothing much you can do to change that if it happens.
Old Mar 29, 2006 | 05:55 PM
Extreme's Avatar
Default Re: preventing the LCA bolt from breaking / stripping? (ekcivic9)
The problem is not the bolt head that froze, most of the time its the bolt shank that got froze to the sleeve of the bushing. You'll know if when you are trying to undo the bolt, you notice the bushing twisting with your motion.
Old Mar 29, 2006 | 06:09 PM
dohcdelsol's Avatar
Default Re: preventing the LCA bolt from breaking / stripping? (Extreme)
PB Blaster the **** out of it
I did it for a week straight before i did my suspension work
Also, i used a torch to heat it up before i even tryed. Came out like butta!!!!
Old Mar 29, 2006 | 06:16 PM
devoxtekxhb's Avatar
use the PB blast, then when re-installing the LCA, apply anti-sieze on the bolt.
Old Mar 29, 2006 | 06:18 PM
ekcivic9's Avatar
i pblastered it tonight... man that stuff gives me a headache and reminds me of melted butter
i hope it works. ill give it a little spray tomorrow after school also.
Old Mar 29, 2006 | 06:25 PM
.Ry's Avatar
.Ry
Default Re: (ekcivic9)
Yup, good job the with PB Blaster every night till d-day! I would strongly advise grap one of them $15 torches at Lowes or Home Depot, and heat that bolt/bushings up. You may hurt the bushing a bit, but you gotta do what you gotta do.
Old Mar 29, 2006 | 07:17 PM
FalkenSiR's Avatar
Default Re: (turner7205)
PB Blasta fo sho
Old Mar 29, 2006 | 07:53 PM
ekcivic9's Avatar
so this stuff should work? im just spraying it on / around the bolts... will it penetrate all the way thru?
Old Mar 29, 2006 | 07:58 PM
.Ry's Avatar
.Ry
It will help, you really need to soak the **** out of those bolts. Make sure it soaks into the bushing to. Make sure when you take those bolts out you dont try and take off the nut, its WELDED to the LCA. Ive seen some people do this and get nowhere lol
Old Mar 29, 2006 | 08:00 PM
Nocturnal's Avatar
You can try hitting it with an impact to see if that would save it from breaking. If it's already really worn out though you might just rip the head off the bolt.
Old Mar 29, 2006 | 09:07 PM
R-Lug's Avatar
Default Re: (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">
ask me how i broke a 19mm socket =P</TD></TR></TABLE>
LOL.. live and learn.. I'm glad that bolt never gave me a problem
Old Mar 29, 2006 | 09:09 PM
B16B_coupe's Avatar
HRD PKR
spray it and drive on it.. or heat it!! mine didnt freaze!!!!!!!! guess i got lucky
Old Mar 29, 2006 | 09:12 PM
ZipTieGUy's Avatar
dude i was in your shoes just 2 weeks ago. i was so paranoid. but guess what, i got some PB blaster and that **** came out like nothign
IAcivicEK
Jul 28, 2007 08:26 AM
TurdBlown Teg
Jul 18, 2006 08:12 PM
BlueIntegraBoy
Apr 24, 2006 08:23 PM
NineInchRails
Nov 1, 2005 04:58 PM
Jebus
10
May 4, 2003 05:03 PM
