b20 rods vs. ls rods?
Old Mar 29, 2006 | 04:30 PM
the.hamburglar's Avatar
Default b20 rods vs. ls rods?
is there any difference between the two. length and strength?
Old Mar 29, 2006 | 04:38 PM
Dan Ruddock's Avatar
Default Re: b20 rods vs. ls rods? (the.hamburglar)
No difference same thing. Dan
Old Mar 29, 2006 | 04:50 PM
projectTeG's Avatar
besides the pistons the bottom end of both engines are identical. the head is identical too, but we ALL already know this
Old Mar 29, 2006 | 06:24 PM
Default Re: (projectTeG)
what is the diameter of the b20 pistons? if its 81mm then how is it making more displacement if the bottom end is the same?
Old Mar 29, 2006 | 06:39 PM
Default Re: (the.hamburglar)
84mm piston with a 89mm crank. Dan
Old Mar 29, 2006 | 06:51 PM
Default Re: (Dan Ruddock)
ohhh, ok thanks. and the rod length of the ls is 89mm as well...
Old Mar 29, 2006 | 06:55 PM
This is handy for all the info your after. Dan
http://www.zealautowerks.com/index.html
Old Mar 29, 2006 | 09:12 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ohhh, ok thanks. and the rod length of the ls is 89mm as well...</TD></TR></TABLE>
the rod length is not 89mm, the stroke is.
Old Mar 29, 2006 | 09:27 PM
Default Re: (4sd4dr)
yeah, the rods are like 130 or something. doesnt matter because they are the same as the ls
Old Mar 30, 2006 | 12:06 AM
vteczone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">what is the diameter of the b20 pistons? if its 81mm then how is it making more displacement if the bottom end is the same?</TD></TR></TABLE>
the b20 with 81mm u refering to is the B20a with 95mm stroke. b20b/z 89mm stroke.
Old Mar 30, 2006 | 12:37 AM
bks84's Avatar
Loved
he's not
anyway displacement is
bore * bore * stroke * .0031416 = total displacement of the engine
84*84*89*.0031416 = 1972cc's or 1.9L's
81*81*95*.0031416 = 1958cc's for the b20a5/b20a3 not sure if you were asking this or not...
coupatroopa
Jun 15, 2010 10:13 AM
boosted97ek
Mid-Atlantic (Sales)
Dec 4, 2008 11:16 PM
jnagel91dx
Mar 17, 2006 08:49 PM
mr_magoo
Nov 3, 2005 10:09 PM
ChiBoy
May 2, 2003 06:40 AM
