HELP!!! No Gas in the injectors
Old Mar 29, 2006 | 03:23 PM
crj_lll's Avatar
Default HELP!!! No Gas in the injectors
My 88 CRX will not turn over. There is spark. There is fuel being delivered to the injectors but when I check the plugs they are as dry as a bone. What is going on? I checked all my fuses. I check the main relay with a brand new one. I checked the computer with a used one. (chances are they would not have the exact same problem.) When the car stopped running I assumed it was the fuel filter and or the distributor so I replaced them both. After that there is no difference. Anyone got a clue? All help is appreciated.
Old Mar 29, 2006 | 03:34 PM
aka's Avatar
aka
Was the car actting up before all this happened? Are you sure you have fuel pressure? Turn the car on and loosen the nut on the filter to see if some fuel squirts out. If it does make sure all the wires in the dizzy clips are all the way in. Did it just stop running while you were driving or did it not start after sitting? check the main relay?
Old Mar 29, 2006 | 03:38 PM
crj_lll's Avatar
Default Re: (aka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aka &raquo;</TD></TR><TR><TD CLASS="quote">Was the car actting up before all this happened? Are you sure you have fuel pressure? Turn the car on and loosen the nut on the filter to see if some fuel squirts out. If it does make sure all the wires in the dizzy clips are all the way in. Did it just stop running while you were driving or did it not start after sitting? check the main relay?</TD></TR></TABLE>
Fuel squirts oput of everywhere I can check. ie. Fuel filter connections and fuel line to injeector connection. The ran one day and not the next. The main relay was already replaced with a brand new one along with a new computer as well. Thanks for the help. All covered already. Need something new.
Old Mar 29, 2006 | 03:41 PM
aka's Avatar
aka
have you checked the timing? maybe it jumped
Old Mar 29, 2006 | 04:06 PM
crj_lll's Avatar
Default Re: (aka)
I will do that. I wonder if I put the distributor on incorrectly.
Old Mar 29, 2006 | 04:07 PM
crj_lll's Avatar
Default Re: (crj_lll)
Keep the suggestions coming. Anythign else it could be?
Projekt CR-X
25
Mar 8, 2011 08:13 PM
QnzEP3
Jan 13, 2011 03:10 PM
uses0ap
May 1, 2009 07:30 AM
hYbRiD EeEkAy
16
Apr 19, 2008 12:37 PM
civicspeed77
May 28, 2003 04:31 PM
