will 225's fit?
Old Mar 29, 2006 | 03:17 PM
civhatch90's Avatar
Default will 225's fit?
im gonna get goodyear 225-55-15 and want to know if i will be able to mount into am oem rim, in this case sunflowers. they are quite wide and im planing to use it as a drag tire. also, will they rub when on the car? btw car is not slammed, and its a hb
Old Mar 29, 2006 | 03:24 PM
rsca_crx's Avatar
Default Re: will 225's fit? (civhatch90)
225/55/15 is a really tall tire.
Old Mar 29, 2006 | 03:28 PM
civhatch90's Avatar
really tall? i would say its really wide, anyways its not for daily driving. will i be able to mount it on the sunflowers?
Old Mar 29, 2006 | 03:35 PM
B18 CYA's Avatar
I will be daily driving on 235/60/15
Old Mar 29, 2006 | 03:47 PM
civhatch90's Avatar
oh oem rims?
Old Mar 29, 2006 | 03:53 PM
rsca_crx's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">I will be daily driving on 235/60/15 </TD></TR></TABLE>
on a crx, you will be going very, very slow, once you manage to get teh wheels and fenders right so that they aren't locked against the trailing arm or the fender. send pictures from the mud pit.
Old Mar 29, 2006 | 03:55 PM
CRX Toad's Avatar
WOW, that is not a good size.
Old Mar 29, 2006 | 04:13 PM
B18 CYA's Avatar
yeah, lots of people talking who actually have not experienced it, just talking from what you think! How will I be going very,bery slow and how is that not a good size?
Old Mar 29, 2006 | 04:24 PM
civhatch90's Avatar
nobody has answered the question yet, will i be able to mount them on oem rims!!!???
Old Mar 29, 2006 | 04:33 PM
B18 CYA's Avatar
yes you will
Old Mar 29, 2006 | 04:35 PM
civhatch90's Avatar
k thanks
Old Mar 29, 2006 | 05:21 PM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">yeah, lots of people talking who actually have not experienced it, just talking from what you think! How will I be going very,bery slow and how is that not a good size?</TD></TR></TABLE>
damn, what the hell is going on today.
i've run 225's for the last 3 or 4 years, and i've been driving a crx in various forms of modification for 9.
235/60/15 is a bad size because it is WAY too tall for anything other than a drag slick. what is the diameter on the tire you're talking about dd'ing? a tire that wide and that tall is going to be nearly impossible to fit under the car (wanna see how hard it is to get 225/45/15's to work well at both ends?). if you do, the diameter is going to make your gearing be terrible. combine that with a lot of added weight, and you are making your car slower.
op- can you put 225's on 5.5 in wide wheels? yes, you can. were they designed to go on wheels that narrow, and will they work as well as a wider wheel- probably not.
Old Mar 29, 2006 | 05:29 PM
B18 CYA's Avatar
m&h 235/60/15 bias ply tires. Diamter is 25.4" . gotta do what you gotta do to to make 400whp stick to the ground
Old Mar 29, 2006 | 05:33 PM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">m&h 235/60/15 bias ply tires. Diamter is 25.4" . gotta do what you gotta do to to make 400whp stick to the ground</TD></TR></TABLE>
not exactly you typical dd tire, certainly not going on all 4 corners, and not going to make many turns. come on man, posts like your first one are why we get people asking about 225/55/15's on oem wheels and dd'ing them without problems.
Old Mar 29, 2006 | 05:34 PM
roterx7's Avatar
i didnt know 225's will fit on the integra flower gsr rims. i thought the widest you can go is 205's on ??x7 rims.
Old Mar 29, 2006 | 05:36 PM
B18 CYA's Avatar
I know it wont be the best for daily driving and I did not say you will have no problems with them. but it is possible to mount them on oem wheels. I am going to run them on oem ls meshies. trust me, i've researched into it enough, I've seen pics of EF's with the exact same tires on. Why should I bother running 205/50/15's if I would just roast them on the street?
Old Mar 29, 2006 | 05:44 PM
FernEF's Avatar
Default Re: (civhatch90)
yea u can. I ran 55's on my ls mesh at one point and car was slammed on the ground and had no problem
Old Mar 29, 2006 | 05:55 PM
godruler's Avatar
Default Re: (FernEF)
your average 225/55r15 is 24.8" tall and 9.2 inches wide and your average 235/60r15 is about 26.1" tall and 9.5" wide, the bare bare minumum rim that should be ran with these tires should be 6" wide. For reference the stock 175/70/R13's on our rex's are 22.7"tall and only 7" wide. and another reference point your stock tire size on most Jeep Cherokee's is 27.7" tall by 8.5" wide. i do not think any of those two sizes above are going to fit a stock ef very well, not even the size that is going to be killer as much as the weight is, how does 25-28 lb's per tire sound, not too good.
Old Mar 29, 2006 | 05:57 PM
B18 CYA's Avatar
Yeah it'll take some work to make it fit, have to jack up the front. Weight of a tire doesn't matter when you're making 400+whp lol.
92integraVTECgsr
28
Sep 19, 2008 12:31 PM
Tiger_Si
Jul 19, 2008 08:18 AM
taimysho0
Jul 9, 2008 04:01 PM
jacoop86
Sep 22, 2007 11:06 AM
crxvtecturbo
Sep 8, 2005 07:41 PM
