Si gauges, Ex cluster
Old Mar 29, 2006 | 03:08 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Si gauges, Ex cluster
00 Si cluster + 96-00 Ex cluster
Is there a topic of discussion on Hybrid Clusters? Searched but didnt find any GOOD info.
Reason being is, i have a Si cluster that seems to be messed up from when i bought my si. I was wondering if there was any threads on how to use the Si gauges on a Ex cluster or anythng.
TIA
If theres not any discussion, hopefully this will start some...
Old Mar 29, 2006 | 03:13 PM
BauleyCivic's Avatar
Risky Business
Default Re: Si gauges, Ex cluster (Stunna BEN)
I got nothin
Old Mar 29, 2006 | 03:14 PM
Stunna BEN's Avatar
Default Re: Si gauges, Ex cluster (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">I got nothin </TD></TR></TABLE>
I got some pics imma post soon.
I got the car it was a dicked up si.
Old Mar 29, 2006 | 03:22 PM
RNPoo7's Avatar
hmm, i'm stuck on this one.
Old Mar 29, 2006 | 03:23 PM
Stunna BEN's Avatar
Default Re: (RNPoo7)
Well imma try it
Just gotta figure out calibration...
Old Mar 29, 2006 | 05:19 PM
B16CRXT's Avatar
Default Re: (Stunna BEN)
What's to calibrate? You will be using the same vss and everything. What are you swapping out?
Old Mar 30, 2006 | 02:21 AM
BlueIntegraBoy's Avatar
You mean swap the Si gauge faces? This is going to be tricky. I've successfully swapped the Si speedo gauge face onto an EX speedo, however, after 80 mph it will become inaccurate since the spacing of the numbers are different after 80 mph. For the tach, I broke the needle pin trying to remove the needle. I don't recommend this. I haven't attempted the fuel/temp gauge since the needles are smaller and are more prone to be broken when trying to remove them.
I had a broken Si cluster to begin with and tried to swap over the faces into my friend's EX cluster.
Project-Ek9
Sep 21, 2008 10:00 AM
jewpont
Dec 10, 2007 09:27 PM
LSVTEC408
Northern California (Sales)
May 27, 2007 06:01 PM
wtfitzphat
May 3, 2006 09:53 PM
outkast_15
18
Jun 24, 2005 03:39 PM
