Emblems
Does anyone know what kinda glue is on the back of the civic, and H emblems? I am thinking of taking mine off and painting them either black or gun metal, then putting them back on. I want them go back on as strong as there were when i took them off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jizzlesmizzle »</TD></TR><TR><TD CLASS="quote">Does anyone know what kinda glue is on the back of the civic, and H emblems? I am thinking of taking mine off and painting them either black or gun metal, then putting them back on. I want them go back on as strong as there were when i took them off.</TD></TR></TABLE>
you can use 3m
WAY back in the day i "smoked my h's"
i used spray tint on the OEM chrome badges
and it came out pretty decent
you can use 3m
I was thinking of removing my "civic" emblem off my 06 Si. However, I am concerned there are some holes in the trunk lid for the emblem. Does anyone know if these holes actually exist?
I am going to try the "dental floss saw" technique tonight. From what I understand you simply use a sawing motion behind the emblem until it gets removed.
I will post more information later once I get it done.
i completely debadged my 07 fg2....soooo clean....there aren't any holes underneath the 'civic' and 'Si' emblems, just adhesive...there are two holes under the honda 'H' emblem though...i just pulled with my fingernail...since our cars are relatively new, the adhesive wasn't cured thoroughly...it was still soft, not hard and brittle....
finger nail polish remover, mineral spirits. If some of the tape is still stuck on use a rubber wheel (you can get one at an autozone or someplace like that) with a drill and it will take it off and not mess up your clear coat. It also takes off bumber stickers and decals no prob.
Break Cleaner and a Rag once the break cleaner hits the adhesive it becomes soft then use a rag or fingernail gently or if you have rubber gloves work great also... thats what i do and works everytime...
just used the hair drier and dental floss method. worked great. i used a soft rubber block to get off the majority of the adhesive, then elmers sticky out to clean up the rest. worked great.
m2s4drespecial
Honda Civic (2001 - 2005)
13
Sep 14, 2007 08:52 AM
HuggerHatch
Feb 12, 2005 09:22 PM
ironchef25
19
Nov 11, 2004 05:00 PM
