DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!!
Old Mar 29, 2006 | 11:45 AM
Speed--Freak's Avatar
Default DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!!
I you guys are like me, then you hate taking off door panels because they always get dorked up from prying etc. Well I figured out a new way to get the job done on almost any car with manual windows.
Here is the problem. You can never get a screw driver between the door panel and the crank without breaking or scratching somthing.
This is the only tool you need. Just a common shop rag. No special tools from the dealer are needed.
This is a two step action. The first step is carfully "flossing" the shop rag behind the window crank.
This is the second step. After you get it into position like so, all you have to do is give it a quick jerk down and it will snag the clip and pop it right off.
This is the end result for all your hard work! You no longer have to screw up you mint door panels when you need to get inside the door.
I know it isn't a CRX in the photos but it will work on just about any car.
Let me know what you guys think.
Old Mar 29, 2006 | 11:47 AM
fernruffryders's Avatar
nice
UltimX's Avatar
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (Speed--Freak)
sounds good... what about putting it back on?
Old Mar 29, 2006 | 11:50 AM
The clip mounts to the crank, so after you put the clip back on the crank, you just push the crank back on to the shaft and it locks itself on..
Old Mar 29, 2006 | 12:15 PM
Jonathan_ED3's Avatar
Are you working on a Toyota or something?
Old Mar 29, 2006 | 12:17 PM
Yes, it's a 92 Camery
Old Mar 29, 2006 | 12:27 PM
UltimX's Avatar
Default Re: (Speed--Freak)
cool! for good info
Old Mar 29, 2006 | 01:55 PM
No2Pencil's Avatar
like magic? nice, now i can drop the needle nose
Old Mar 29, 2006 | 02:03 PM
Its me DUB's Avatar
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (No2Pencil)
nice. i made one by cutting a 5 inch section of wire clothes hanger and bending it like an L. works good and i don't scratch anything, but yours looks like a good idea too. I'll try it next time and compare
Old Mar 29, 2006 | 02:42 PM
popeface's Avatar
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (doitdub)
Nice... my Haynes manual says to do that... I'm not cool enough for the Helms yet. I tried the rag trick and it's annoying and not too easy to get the rag into proper position, so I just have a long strip of chicken wire that I've twisted into loops at both ends... all I do then is just gently pull back on the handle, slide the loops over the clip on either side, then yank down on the wire. Works every time...
Philly
Old Mar 29, 2006 | 02:46 PM
rsca_crx's Avatar
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (popeface)
nice. now i feel stupid for spending 10 mins a pick last weekend.
Old Mar 29, 2006 | 03:59 PM
EL Vap133's Avatar
I just use a slim flat screwdriver.
Old Mar 29, 2006 | 04:07 PM
408wdy's Avatar
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (EL Vap133)
word
Old Mar 29, 2006 | 04:09 PM
Tippyman's Avatar
Ithink i'll stick to a long needle nose and just pull the clip off. That feels like my window crank is about to break off.
Old Mar 29, 2006 | 04:17 PM
k7q's Avatar
k7q
Default Re: (Tippyman)
whoa ill do that next time instead of using my screw driver.
Old Mar 29, 2006 | 04:22 PM
fastcrx420's Avatar
pocket knife
Old Mar 29, 2006 | 04:27 PM
wood's Avatar
This is great advice, but it is in most DIY repair manuals. Good tip for those who don,t have any manuals!
Old Mar 29, 2006 | 04:53 PM
Jonknee's Avatar
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (wood)
i used pliers and raped my panel.
Old Mar 29, 2006 | 05:31 PM
goforbroke's Avatar
MEAT PATTY
Default Re: DIY THE BEST WAY TO GET YOUR WINDOW CRANK OFF!!!!!! (efnewb91)
I use a fork. I just bend the middle two stems about 1/8 of inch and just slide it down in their. It acts like a hook and yes I keep a fork in my tool box just for that.
Old Mar 29, 2006 | 05:36 PM
roterx7's Avatar
thats how yourssuppose to do it. it even say so in the book
Old Mar 30, 2006 | 10:12 AM
No2Pencil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I just use a slim flat screwdriver. </TD></TR></TABLE>
or a rag
Old Mar 30, 2006 | 10:17 AM
Sleeper91's Avatar
Nice write up
Old Mar 30, 2006 | 10:49 AM
Blanket Jackson's Avatar
Damn nice, but how can I get the thing back on????
Old Mar 30, 2006 | 11:09 AM
menappi's Avatar
this is old, ive been doing this for years. but its a good idea! 2 get the clip back on it works great too.
Old Mar 30, 2006 | 12:44 PM
Tyson's Avatar
Default Re: (menappi)
i used to use those aftermarket stereo hooks shaped kinda like a U to pull the clip out. but a screwdriver or plier will do fine, i dont see the need for making a big deal about it.
as for getting it back in, just put the clip in the handle fully engaged, then push the handle back on the spindle. locks into place.
