Need info on Atts Tranny
Old Mar 29, 2006 | 11:29 AM
YEABOY's Avatar
Default Need info on Atts Tranny
ok, so I bought a 95 GSR with no motor. then I found a great deal on a complete H22 with tranny, so I got that. I started buying everything for my H22 in Teggy swap. Axles, Half Shaft, Mounts, Shifter Cables. Then it came down to putting it together. so as I was putting it together I noticed the Half shaft wouldn't go in. The tranny hole is way bigger. So I did research on motor. Come to find out its from a Prelude Type SH, with ATTS. So im screwed aren't I? I wanted to know what are your guys opinion on this. Is there a special Half shaft they sell that can go in the tranny? Or should I just sell the motor, or just tranny and still use the motor?
Need Help, Want car running
Modified by Integ4Life at 2:44 PM 3/29/2006
Old Mar 29, 2006 | 12:19 PM
The Weather Man's Avatar
Just get an m2a4 tranny or something. No need to sell the entire engine assembly.
Old Mar 29, 2006 | 12:26 PM
YEABOY's Avatar
Default Re: (The Weather Man)
But does any one know if they sell a special half shaft for this? Couse its gona be hard to try and sell this tranny.
Old Mar 29, 2006 | 01:52 PM
Daemione's Avatar
Default Re: (Integ4Life)
Nope, you'll need to get a base tranny if you want to use the engine. You use the base intermediate shaft with a custom bracket to mount it on the block (where the ATTS used to be).
Old Mar 29, 2006 | 02:20 PM
Chuckles99SH's Avatar
Default Re: (Daemione)
Base tranny doesnt match up with the SH block there are a few small changes to the SH block vs the stock H22a4 block. I have heard of people using an adapter plate for the intermidiate shaft.. but the local tuner shop in my area deemed it unsafe and wouldn't do it. Probably why you got a great deal on the motor/tranny because its really only gonna be easy to put back into an lude SH.
GL
Old Mar 29, 2006 | 03:49 PM
YEABOY's Avatar
Default Re: (Chuckles99SH)
Well I guesse thats it for My H22, then. If you guys know anybody wating a H22 Type SH let me know. Thanks guys
da9 jdm717
Feb 16, 2012 03:15 AM
mdj_ge
Dec 22, 2004 06:34 PM
preludeserge
Dec 11, 2004 04:33 AM
wreckedmyteg
Jul 18, 2004 06:30 AM
money
Apr 15, 2003 06:34 AM
