??STAINLESS STEEL BRAKE LINES??
I have a 94 integra and i want to get some stainless steel brake lines. just woundering what would be some goods ones, kind to you have on your teg, and can you show me some pics. thanks!!
I would be careful about using the stainless steel brake lines. Personally i don't believe they are meant to be used for daily driving, but its your car and you could do whatever you want to it. But if you were to put them on i would regularly check on them for any unnormal wear. Here are a few links that discuss stainless steel lines - https://honda-tech.com/zerothread?id=1199349 and this one is a very good read http://www.nsxprime.com/FAQ/Pe...s.htm
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">I would be careful about using the stainless steel brake lines. Personally i don't believe they are meant to be used for daily driving, but its your car and you could do whatever you want to it. But if you were to put them on i would regularly check on them for any unnormal wear. Here are a few links that discuss stainless steel lines - https://honda-tech.com/zerothread?id=1199349 and this one is a very good read http://www.nsxprime.com/FAQ/Pe...s.htm
Ali</TD></TR></TABLE>
eh...I've been driving w/ stainless steel lines for years on my prelude, Integra and just put some on my RSX (knew I couldn't keep it totally stock). I think, if ABNORMAL wear would surface, if would be from the user like the guy in your first link and in my experience...
Stainless lines are great for any situation.
I run Earls lines...Either those, goodrich or the lines from Fastbrakes would be a good decision.
Stoptech rock! Perfect fitment with all the pieces you need. You would think they were stock replacements.
I have used SS lines on all my vehicles for daily and track use, I have had zero problems.
iperez
Sep 7, 2004 03:27 PM
