grounding systems??
Old Mar 29, 2006 | 05:30 AM
dc r-spec's Avatar
Default grounding systems??
Just kinda curious to see if anyone has any experience with any of the grounding/voltage stabilizing systems out on the market now. Looking at probably the HKS system, but didnt know if anyone had any negative or positive experience with them. Let me know if you guys have any installed on your rides, pics of grounding locations would also be helpful, from those who do and have made power.
Old Mar 29, 2006 | 07:16 AM
dc r-spec's Avatar
Default Re: grounding systems?? (dc r-spec)
anyone
Old Mar 29, 2006 | 11:19 AM
2SlowDC's Avatar
i want to know too
Old Mar 29, 2006 | 11:48 AM
dc r-spec's Avatar
Default Re: (No-Tec)
back up to the top anyone have any input
Old Mar 29, 2006 | 02:18 PM
Top Ramen's Avatar
Default Re: (dc r-spec)
I have been skeptical of them, but they allways seem to pick up a few hp in tests. In fact, a couple of years ago, I was chatting with a guy who is an editor at Sport Compact Car and he was telling me they were going to test one just to put rest all the bullshit about how they improve performance. Problem was, when they dyno tested it, the car picked up a couple of hp.
Don't buy one, though. Just go to a good stereo shop and buy some high gauge wire and some good connectors and make your own. Half the cost and will work just as well.
Old Mar 29, 2006 | 02:49 PM
JCushing's Avatar
Default Re: (Top Ramen)
some of the more expensive kits come with voltage regulators..... like the sun kit
i opted to convert all my old car stereo wires in to grounds though
Old Mar 29, 2006 | 05:00 PM
broketuner-Sol_Si's Avatar
Default Re: (JCushing)
I have both a sun grounding and voltage stabilizer kits. I can say that the car seems to idle smoother. didn't really notice too much else.
Old Jun 8, 2006 | 09:10 AM
2slow_Eg2's Avatar
Default Re: (broketuner-egb16a)
does anyone know where the grounding locations are? i want to try it out on my delsol. thanks
Old Jun 8, 2006 | 10:39 AM
polymath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">some of the more expensive kits come with voltage regulators..... like the sun kit
i opted to convert all my old car stereo wires in to grounds though</TD></TR></TABLE>
I would be concerned what the regulator was doing to the rest of the system. Where does it regulate? What's the output voltage? What's the loss in amperage?
Is it a regulator, or is it really a supressor or condensor?
I just grabbed some 0 and 4 gauge cable from work and soldered and heat-shrunk some terminals on it and made my own.
Old Jun 8, 2006 | 10:42 AM
polymath's Avatar
Default Re: (2slow_Eg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow_Eg2 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know where the grounding locations are? i want to try it out on my delsol. thanks </TD></TR></TABLE>
I ran mine to the back of the head, just infront of the brake booster (there's a threaded hole you can screw a 14mm bolt into); on the transmission (one to the factory spot, and one to a chassis/junction I made near the battery - total of 2 leads); one to the factory ground on the water inlet/thermostat housing; and one to the distributor.
Old Jun 8, 2006 | 11:00 AM
sinister6's Avatar
Default Re: (Coyote1800cc)
I have the Pivot unit, besides the stereo 'SEEMS' more clear with radio stations, I dont feel any improvement.. but then i didnt dyno the car..
Old Jun 8, 2006 | 11:54 AM
1337whp's Avatar
Default Re:
i used 6 guage cooper and a some nice gold connectors, and it will work
Old Jun 8, 2006 | 12:40 PM
aZnjCC's Avatar
No experience with voltage stabilizer kits, but made my own ground wire kit.
4-gauge power wire and gold connectors made to the same lengths as the sun auto kit. Didn't really notice anything.
allyourapex
Mar 23, 2010 11:00 PM
NirVTEC
May 28, 2005 07:14 AM
H22aAccord
Sep 5, 2004 11:02 AM
B18C2_sedan
Nov 29, 2002 06:41 PM
Cosworth
Jan 25, 2002 09:38 AM
