What harness do i need?
I tired a search and I coldnt find what i was looking for and i just wanted to be for sure b4 i bought it. I have a 90 crx dx and im putting in a d16y8 or a z6 i forget witch one it is out of a 95 del sol si its the sohc vtec. I just need to know what wiring harness i need from hasport, im pretty sure i just need this 88-91 Civic and CRX Wiring Subharness for HF/Si with VTEC engine. EFSI-VTEC , but if not could you plz tell me witch one thanks.
You will need it specifically for your car. The HF/Si harness will not work unless you have converted to MPFI.
Just call them that is what they are there for.
Dam, i was hoping that i would get away with just buying the $79.99 harness, i have a feeling if they have to make a diffrent one its going to be hella exspensive. Can i just change the plugs and put the pins in the right spots?
no getting around converting the car from DPFI to MPFI - use the engine harness for the car and do all the wiring changes to it - or, get Rywire harness:
http://rywire.com/store/produc...67082
I just thought of somthing would it help if i had a engine harness from a hf and the harness that goes to the ecu? if so i have one.
deftones0817
21
Feb 21, 2004 01:27 PM
